Hello Guest it is April 26, 2024, 07:39:28 AM
Author Topic: Impact engraving plugin  (Read 360159 times)
  •  9,200 9,200
Re: Impact engraving plugin
« Reply #310 on: January 26, 2017, 09:50:02 AM »
Very nice work Jan Mozol.
« Reply #311 on: January 26, 2017, 09:54:19 AM »
Does this diagram help ?
Is laser's active low trigger input the same TTL input related to the power supply of laser?? Shall I connect the output of the pin allocated to the Digit Trig to TTL input of power supply laser??!
  •  9,200 9,200
« Reply #312 on: January 26, 2017, 09:58:38 AM »
My diagram shows typical Mach3 connection to a laser power supply.
If you are not certain of your particular connections you should seek the advice of a laser engineer in your area.
« Reply #313 on: January 26, 2017, 10:26:08 AM »
my laser power supply is different from the diagram that you have sent me. my power supply consists of 6 pins that i should connect them to wires , one is 5V,TH,TL,WP,G,IN . at the moment i have connected pins IN and G to output inverter spindle .
  •  9,200 9,200
« Reply #314 on: January 27, 2017, 01:29:39 AM »
That is correct pins IN and G will control laser power related to the duty cycle of the PWM signal.
Pins TL and G are the pins that would be used to switch the laser on / off (at the power level set by the PWM once M3 has been called) using the Digital Trigger from Mach3.
« Reply #315 on: January 27, 2017, 01:51:40 AM »
which pin should be allocated to Digital Trig ?
  •  9,200 9,200
« Reply #316 on: January 27, 2017, 02:04:21 AM »
Any spare output pin that you have unused.
I use port 1, pin 16 (enabled and set active low).
« Reply #317 on: January 27, 2017, 03:14:01 AM »
Thanks a lot. Do you have the download link for plugin impact/engraving TOMTOM or the newest version of this??
  •  9,200 9,200
« Reply #318 on: January 27, 2017, 03:23:12 AM »
You need to contact Kazuki Tomura for his plugin.
« Reply #319 on: January 27, 2017, 03:53:35 AM »
Hi guys , just came to show jewels (pingents) being made by impact plcin, this time I reduced the speed...just 5000 mm/minute!
These are my son, and my wife!
https://youtu.be/qFBbIUDsGWM
Nice work, Jan. Just 5000mm/min?! You gotta' be kidding! I can't get my self-made solenoid move faster than 30 times/sec (30HZ).
I still was not able to contact the plugin creator or find this plugin elsewhere.
