Hello Guest it is April 26, 2024, 12:50:27 AM
Author Topic: Impact engraving plugin  (Read 360092 times)
Re: Impact engraving plugin
« Reply #130 on: April 04, 2011, 05:56:06 AM »
hi,
     I'm at work, I can not put my, give me your control that.
« Reply #131 on: April 04, 2011, 06:16:01 AM »
     I managed to retrieve the settings.
Try to see if it works well.  ;)
  •  9,199 9,199
« Reply #132 on: April 04, 2011, 06:42:58 AM »
ntlaser,
Are you getting double image similar to post 109 ?
Are you sure you are using the latest version of the plugin 2.00.075 ?
« Reply #133 on: April 04, 2011, 06:50:44 PM »
Tweakie i have the latest version!! Laser 78 I dont see any difference.I face this problem since the beginning and I cannot find any solution:(
« Reply #134 on: April 05, 2011, 02:31:31 AM »
   could you give me your setup?
Andrea
  •  9,199 9,199
« Reply #135 on: April 07, 2011, 02:15:59 AM »
ntlaser,
Could you please post a picture of the double image you are getting.
« Reply #136 on: April 10, 2011, 05:15:33 PM »
Hello.I am posting the photos of the double image.With some other test I did ,I notice that the images come closer if i reduce the speed.I really dont know what to do!!
« Reply #137 on: April 11, 2011, 02:06:52 AM »
   give me your setup to control a thing.
Ciao Andrea.
  •  9,199 9,199
« Reply #138 on: April 11, 2011, 02:16:46 AM »
ntlaser,
Looking at your Micken Mouse, the double image is not linear and this suggests to me that there could be a delay between the Mach digital trigger pulse being sent and the laser actually firing. Maybe that reducing your feedrate to something around 4 to 5 thousand mm/minute may produce different results.
« Reply #139 on: April 11, 2011, 04:46:24 AM »
Tweakie thanks,
but when i am reducing to 5000mm/min the laser doesnt fire!
