Hello Guest it is April 18, 2024, 02:18:25 PM
Author Topic: AL54b (lathe) project from New Zealand  (Read 165642 times)
Re: AL54b (lathe) project from New Zealand
« Reply #90 on: November 20, 2010, 07:18:49 PM »
1. I have 2x 269oz 2x 387oz 2x 425oz step motors from PH http://homanndesigns.com/store/index.php?main_page=index&cPath=25 my plan was to use a 269 for my X axiz and the 387 for the Z axis is this the best option?
I would think so, but maybe the heaviest axis would be best with the biggest motor.
The 425oz are slower, ill try it and post the results.
3. Is it possible to have a third axis that when enabled (with a switch) homes itself, then goes to the current z axis position, then mirrors  the z axis?
Not sure about this, would need more explanation of what its actually for and when its going to be used.
More on this coming soon, ill get it all straight in my head frist.
thx
« Reply #91 on: November 20, 2010, 09:41:57 PM »
"Gas springs" are the technical name for them. Searching for this term instead, may lead you to better, cheaper sources.
« Reply #92 on: November 21, 2010, 01:44:59 AM »
I will second what Hood said - belt drives are easier to setup and in my opinion are the correct way to build a good machine. I think a 2:1 reduction will work great with the motor you chose. Another thing to consider when choosing the drives is the motor voltage. The G251 are 50V, so motors should be rated not more than some 3-4V if you want to get the max speed out of them.
« Reply #93 on: November 21, 2010, 02:54:54 AM »
Thanks for the reply Dan, I don't see how motor voltage makes a difference as long as the PSU is also 50v can you please explain.
2:1 is the motor the 2 or the 1?
thanks.
« Reply #94 on: November 21, 2010, 04:20:07 AM »
motor would be the 2
« Reply #95 on: November 21, 2010, 07:06:33 AM »
thanks.
Read this guide on stepper motors: http://geckodrive.com/upload/Step%20Motor%20Basics%20Guide.pdf
A very informative one.
And yes, the motor does 2 revolutions for each revolution of the screw.
« Reply #96 on: November 21, 2010, 02:13:46 PM »
High speed torque increases as the ratio of the motor power supply to coil voltage increases. Typically, voltage to the motors are between 4-10 times the motors stated value. If your motors are 5V, then 10x5=50, and then your drives are at their maximum rated voltage. If your motors are something like 20v, then 10X20= 200V, which is way more than the drive will handle. If it were me, I would look for something under 5v, and stay away from maxing out the drive.
« Reply #97 on: November 21, 2010, 02:33:07 PM »
http://www.gasspringstruts.co.uk
http://www.strutsdirect.co.uk
seems pretty reasonable from the small amount of browsing I done.
« Reply #98 on: November 21, 2010, 03:24:51 PM »
Can i make what i have work? what will be the downside if i do use what i have?
« Reply #99 on: November 21, 2010, 03:58:37 PM »
Gas strut $15, Shipping to NZ $65 Nice.
