Brian, When I input the following into the New Fang. Cut Arc Wizard - no arc is indicated in the Preview, Verify Toolpath, or initially in the machine screens in Mach 3. Oddly enough, the arc does show up when running the G-code.
Input are : X Center 3, Y Center 3, Circle Radius 1, Start Angle 75, Arc Sweep 180. Other inputs near these coordinates are producing similar results.
Also, is it possible to have the Please Choose Tool Properties dialogue screen in the Suite of Wizards pull data from the tool table file. tool diameter, etc.
Bob @ BobsShop
