Hello Guest it is April 20, 2024, 12:45:19 AM
Author Topic: arduino mega to mach3 prototype  (Read 15044 times)
« on: October 30, 2010, 12:21:31 PM »
read 'explain' file for details. if there are questions, i will just answer them.
Re: arduino mega to mach3 prototype
« Reply #1 on: October 30, 2010, 01:53:34 PM »
Really nice work! My system is in 1k pieces at the moment but I'll try it out sometime when its back online.
« Reply #2 on: December 28, 2010, 07:51:32 PM »
Nice job, I have an Ikegai lathe that is similar to yours, How did it run? I think I will do something very similar when I retrofit mine.
I have a bunch of questions if you dont mind:
1. If it has the Fanuc DC servos on it like mine, How did the drives work out? They look nice and are a decent price.
   Also if they are the Fanuc DC servos can you give me some hints or a diagram on how you wired the encoders to your drives?
2. You must be using the arduino for tool change logic and also getting inputs from switches and other things into mach3 how did that all work out?
3. Did you get the bugs worked out?
4. Does your lathe have the hydraulic operated turret? controlled with SOL valves and a hyd. motor? If so how hard was it to implement the tool change logic?
I almost convinced myself that it would be easier to use a geared servo for the turret positioning.
I would really appreciate this info it would save me alot of research.
« Reply #3 on: July 07, 2015, 06:14:14 PM »
problems
Offline dude1
  •  1,253 1,253
« Reply #4 on: July 07, 2015, 06:30:17 PM »
remove byte
« Reply #5 on: July 11, 2015, 03:27:48 PM »
Now work output pins relay work but we do not input error, "CRC error"
What is the problem Bass configuration mode
Offline dude1
  •  1,253 1,253
« Reply #6 on: July 11, 2015, 04:20:11 PM »
you wont have the CRC library or it needs updated c/program files/arduino/hardwear/arduino/avr/cores/arduino
