Hello Guest it is April 26, 2024, 11:14:33 PM
Author Topic: Hitachi X200  (Read 131862 times)
Re: Hitachi X200
« Reply #10 on: October 29, 2010, 04:24:53 PM »
Nevermind, I found the DRO you were referring to, it is called 'CMD Spindle RPM'
So i now can turn it on and set speed  :D
Re: Hitachi X200
« Reply #11 on: October 29, 2010, 04:32:05 PM »
Glad to see it is working.
Do you want to post the brain so that other owners of a Hitachi  can use it?
Cheers,
Peter.
Homann Designs
http://www.homanndesigns.com
Re: Hitachi X200
« Reply #12 on: October 29, 2010, 04:53:22 PM »
I sure will.  I actully used 2 different brains for trouble shooting purposes.
Also I had to do 1 more little trick, instead of using the 'CMD Spindle RPM' value in the formula, I had to use the 'Spin RPM - Overridden' DRO so that spindle speed override would work :)
Also in the VFD Run brain I didnt concern myself with reverse, since I have a wood router and wont be using revrse much (if at all)
Thanks for all your help Peter!!!
Offline Greolt
  •  956 956
Re: Hitachi X200
« Reply #13 on: December 21, 2010, 04:31:20 PM »
I need to ask a embarrassingly basic question.  :D
What cable do I need to connect modbus to the SJ200 ?
Hitachi manual says, pin 5 send/receive data positive, and pin 6 send/receive data negative on the RJ45.
But no info on the computer end. Probably because it is so obvious that any fool would know.   ;D
Any one help?
Greg
Re: Hitachi X200
« Reply #14 on: December 21, 2010, 05:40:54 PM »
Hi Greg,
You need an rs232 to rs485 converter. The rs232 end goes into the computer. The RS485 end connects to the X200.  You will have to make this cable up. The converters usually have screw terminals on the RS485 end and a DB9 on the RS232 end.
You will need to buy Something like this.
http://cgi.ebay.com.au/RS232-RS485-DATA-COMMUNICATION-CONVERTER-ADAPTER-/140441135202?pt=AU_Components&hash=item20b2f1a862
Cheers,
Peter.
Homann Designs
Re: Hitachi X200
« Reply #15 on: December 21, 2010, 05:43:13 PM »
Greg,
In addition to the 2 data wires, you also need a 0V line between the X200 and converter.
Cheers,
Peter.
Homann Designs
Offline Greolt
  •  956 956
Re: Hitachi X200
« Reply #16 on: December 21, 2010, 05:45:30 PM »
Thanks Peter.
On the way from HK ebay.
Have a great Christmas with the family.
Greg
Offline Greolt
  •  956 956
Re: Hitachi X200
« Reply #17 on: January 06, 2011, 05:58:00 AM »
Got my RS485 converter.   Set all the options for modbus in the Hitachi.  Think they are right.  ???
I have communication...but,
Reading and writing to coils looks to work.
Reading Holding Registers also seems to work.
Writing to Holding Registers just gives a timeout.
So I think this is why I can not get the spindle to run.    Can turn on the run and CW signals but can not set the frequency (RPM) so it does not run.
Any ideas what I am doing wrong?
Greg
Offline Greolt
  •  956 956
Re: Hitachi X200
« Reply #18 on: January 06, 2011, 06:25:03 AM »
Zigmart
Can you tell me what settings in the Hitachi you have for,  (my settings in parenthesis)
C070  .....NA in SJ200.  set via dip switch
C071  (05)
C072  (1)
C074  (00)
C075  (1)
C076  (02)
C077  (50)
C078  (10)
Probably only the last two are questionable.
Greg
Offline Greolt
  •  956 956
Re: Hitachi X200
« Reply #19 on: January 09, 2011, 06:27:36 PM »
I also have a X200.  So I tried the modbus with that.
Exactly the same result.   Read and write to coils OK.   Read holding registers OK.  Write to holding registers results in a time out.
Doing something wrong but have no idea what it is.
Tried all sorts of settings for C077 and C078.   No joy.
I am shooting in the dark here.  :)
Greg
