Hello Guest it is June 10, 2026, 03:55:45 PM
Author Topic: Want to try Mesa Elec  (Read 262517 times)
« on: September 15, 2010, 10:04:46 PM »
Hello Steve
Need/want to try the Mesa Electronics to replace Delta 40 controller and will need your Plugin so as do use Mach.  Can I do this
racear
Re: Want to try Mesa Elec
« Reply #1 on: January 02, 2011, 10:17:58 AM »
Perhaps edit your Top Posting to include a hyperlink to the web site for the MESA boards.
Offline smurph
  •  1,575 1,575
« Reply #2 on: January 13, 2011, 11:48:29 AM »
Racear.
The plugin is still in development.  You can test it out if you like, but I would not consider using it for a production machine at this point.  PM me with your email address if you want to try it out.  But there are no guarantees that it will work.  You will have to be pretty knowledgeable about Mach, your servo drives, and your PID tuning to solve your own problems, as I will not be able to give you that level of support.
Steve
« Reply #3 on: April 16, 2012, 02:27:53 PM »
hi there i would like to use mach to control my plasma gantry with the mesa 5i20 is the plugin far off being ready? and if not in what way is it not production ready
would like to use this for a esab gantry machine with a dead control retrofit
many thanks john
