Hello Guest it is April 18, 2024, 07:55:30 PM
Author Topic: cine ma pate ajuta sa conectez un driver TB6560 cu mach 3  (Read 7122 times)
« on: September 12, 2010, 09:14:23 AM »
as vrea sa stiu cum se conecteaza un cnc driver TB6560 cu mach 3 .
ajutoooooooor
Re: cine ma pate ajuta sa conectez un driver TB6560 cu mach 3
« Reply #1 on: September 22, 2010, 12:34:47 AM »
    Salut,
Ai citit documentatia? Acolo gasesti informatii utile despre cum anume trebuie conectate "driverele" la portul paralel al PC-ului.
« Reply #2 on: December 27, 2010, 01:30:24 PM »
salut morarudnl
si merci de raspuns!
nu am gasit nimic cum sa setez corect curentul pentru motoare : am motoare de 2A . in documentatie scire doar atit:
Adjustable 1.5A-3A drive current settings for each axis - 25%,50%,75%,100% of full current can be set for different stepper motors
« Reply #3 on: December 28, 2010, 05:32:44 AM »
Salut,
 Am atasat un fisier pdf cu informatiile necesare.
Succes.
Daniel.
« Reply #4 on: January 01, 2011, 03:26:30 PM »
mersi daniel - si anul nou fericit!!
