Hello Guest it is March 29, 2024, 10:49:11 AM
Author Topic: Help - phone support - size problems  (Read 4162 times)
Offline Bill_O
  •  563 563
« on: September 07, 2010, 09:50:20 PM »
Is there any way I can just pay with a CC? I have problems with paypal.
I am an OEM.
cell phone 972-897-2415
email1 ; oelklaus@computerizedcutters.com
email2; bill_oelklaus@yahoo.com
I am at the end users site and need help now.
The below info is from the yahoo group. Just for info.
I had the machine set to exact stop. This router will run any one axis at 1350
inches per minute at 1/2 G acceleration. When I ran this test the router was
only running at 100 in/min. I would think if it was a rounding issue at some
point on the diamond it would be the correct size.
Bill
--- In mach1mach2cnc@yahoogroups.com, <testfly@...> wrote:
> G64 and G61
> CV set ON will round corners
> ----- Original Message -----
> From: Will Schmit
> To: mach1mach2cnc@yahoogroups.com
> Sent: Tuesday, September 07, 2010 5:09 PM
> Subject: Re: [mach1mach2cnc] Re: size issues
> I would put a dial indicator on the bed - step it 1 cm, and see if you get 1
cm
> Then turn the setup 90 degrees and step 1 cm in the second direction.
> Have you adjusted the g-code to run at dead slow, to see if you are losing
> steps?
> It is unlikely, or your whole job would be wandering off.
> There is a command that helps with stuff like this -- it is a g-code that is
> something like "come to stop" which doesn't flow to the next command until
the
> statement is satisfied.
> Someone better versed than I will know the statement.
> Keep teklling the group what is happening, and they will help
> ________________________________
> From: William <oelklaus@...>
> Sent: Tue, September 7, 2010 5:57:05 PM
> Subject: [mach1mach2cnc] Re: size issues
> Will,
> Circles are small and large where in the same directions as the diamond.
This is
> a big fast high end machine. It is an 8x25 foot cut area with helical racks,
> high end gear boxes, Yaskawa servos, etc. I do not think it is backlash. If
it
> was backlash I think I would see it even doing a square along the x and y
axis.
> I could be wrong and would like to know how you might suggest I check?
> Thanks,
> Bill
> --- In mach1mach2cnc@yahoogroups.com, Will Schmit <anchornm@> wrote:
> > What about circles?
> > A circle might help you zero in on whether it is a backlash problem or an
> > increment set-up problem.
> > From: William <oelklaus@>
> > Sent: Tue, September 7, 2010 5:30:10 PM
> > Subject: [mach1mach2cnc] size issues
> > I am working on a router that has a problem making diamond shapes correct.
If a
> > square is cut along just x and y moves the sizes are even. If the same
square
> >is
> > rotated 45 deg, 2 sides are long and 2 sides are short. The long sides are
on
> > opposite sides of the square and so are the short sides. I need help with
this
> > bad.
> > Thanks,
> > Bill
