Hello Guest it is April 26, 2024, 06:24:28 AM
Author Topic: Work Offset Parameter Values?  (Read 3929 times)
« on: September 05, 2010, 05:42:05 AM »
Hi,  I notice that the Work Offset Parameter numbers are offset by one.  Is this a quirk of my installation or is there updated documentation somewhere? I have looked and searched without success. Thanks, Kit
Re: Work Offset Parameter Values?
« Reply #1 on: September 05, 2010, 08:10:11 AM »
Not sure what you are meaning, is it when you call G55 then G56 shows or is it the DRO for each axis is off by 1 from what you think it should be?
« Reply #2 on: September 05, 2010, 04:22:59 PM »
Hi,  I am writing a value to Parameter Number 5243, which, according to the documentation I have, is Work Offset 2Y. But it appears on the Offsets Page as Work Offset 2Z, and after a G55 the Z axis position reflects the new Y offset. I am only using work offsets 1 and 2 at the moment and I can cope with entering the parameter values I need by offseting the location by one, but it would be reasuring to get to the bottom of this.  Cheers, Kit
« Reply #3 on: September 05, 2010, 05:31:33 PM »
Afraid I have never used parameters to change offsets so cant say whether they are correct or not, dont even think I have a list of them :D
« Reply #4 on: September 05, 2010, 09:49:09 PM »
It is a error in the book . If you notice where the descriptor "Workoffset values" is it spills over to the next line and it OFFSET the numbers by one line. It was never corrected.
I have a list somewhere BUT it is a VERY VERY long list.
« Reply #5 on: September 05, 2010, 11:10:50 PM »
Thanks guys, That puts my mind at rest.  Just to clarify, this thread refers to figure 10-1 in the Mach3 Users Guide. As BR549 points out, after parameter number 5220 all parameter numbers are offset by one.
