Hello Guest it is April 25, 2024, 04:21:37 PM
Author Topic: "An attempt was made to access an unnamed file past its end" Error  (Read 11108 times)
what is this problem Please help me !!!
Problem file is here
Re: "An attempt was made to access an unnamed file past its end" Error
« Reply #1 on: September 01, 2010, 03:37:34 AM »
Hello,
the *.set-file looks totally messed up. From the first look I would say, every byte which should be zero (0x00) is a blank-character (0x20). Did you edit or convert this file with another program than a screen-editor?.
Klaus
The brain isn't a soap, it doesn't shrink when used.
« Reply #2 on: September 01, 2010, 09:48:33 AM »
I do not know. My dealer had sent it to me. Open text editor and I think a line was deleted.
I deleted the zone in here
Code: [Select]
     NoneNone'C:\Mach2\"something in there"     Label
« Reply #3 on: September 01, 2010, 10:36:34 AM »
MachScreen saves the loaded file with the filename and an incremented number in the file-extension. If you haven't loaded your set-file more then five times, you could try the following:
Rename your file THC300M3.set to THC300M3.old
rename TCH300M3.SEn with the highest number to THC300M3.set
try to load the set-file. If this doesn't work, I'm afraid you have to ask your dealer for that file again, or you use another set-file like 1024.set, if that fit's your demands.
Klaus
