Welcome, Guest. Please login or register.
Did you miss your activation email?
May 20, 2013, 03:56:36 PM
Login with username, password and session length
Search:     Advanced search
* Home Help Search Calendar Links Login Register
+  Machsupport Forum
|-+  Mach Discussion
| |-+  Mach Screens
| | |-+  "An attempt was made to access an unnamed file past its end" Error
Pages: 1   Go Down
Print
Author Topic: "An attempt was made to access an unnamed file past its end" Error  (Read 2384 times)
iSuat
Active Member
Offline Offline
View Profile
« on: August 31, 2010, 03:20:35 PM »
what is this problem Please help me !!!
Problem file is here
* THC300M3.set (87.84 KB - downloaded 105 times.)
Logged
Klaus1311
Active Member
Offline Offline
View Profile WWW
« Reply #1 on: September 01, 2010, 02:37:34 AM »
Hello,
the *.set-file looks totally messed up. From the first look I would say, every byte which should be zero (0x00) is a blank-character (0x20). Did you edit or convert this file with another program than a screen-editor?.
Klaus
Logged
iSuat
Active Member
Offline Offline
View Profile
« Reply #2 on: September 01, 2010, 08:48:33 AM »
I do not know. My dealer had sent it to me. Open text editor and I think a line was deleted.
I deleted the zone in here
Code:
     NoneNone'C:\Mach2\"something in there"     Label
Logged
Klaus1311
Active Member
Offline Offline
View Profile WWW
« Reply #3 on: September 01, 2010, 09:36:34 AM »
MachScreen saves the loaded file with the filename and an incremented number in the file-extension. If you haven't loaded your set-file more then five times, you could try the following:
Rename your file THC300M3.set to THC300M3.old
rename TCH300M3.SEn with the highest number to THC300M3.set
try to load the set-file. If this doesn't work, I'm afraid you have to ask your dealer for that file again, or you use another set-file like 1024.set, if that fit's your demands.
Klaus
Logged
Pages: 1   Go Up
Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
