Hello Guest it is October 27, 2026, 06:39:47 PM
Author Topic: Arduino Mega with MACH3  (Read 70146 times)
« on: August 31, 2010, 08:59:48 AM »
I just ordered an Arduino Mega. When I saw the amount of public open source code, and hobby/robotics accessories available I had to try.
I found some MODBUS software, and the MACH3 can 'open' the board.
I am not a good programmer at all, but I want to try to get them talking.
My plan is to try every combination of setting and jumpers on the board,and in MACH3  until I get some response.
If anyone has any better ideas or resources I am very interested
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
Re: Arduino Mega with MACH3
« Reply #1 on: September 11, 2010, 11:13:34 AM »
I've had a bit of a play with this http://sites.google.com/site/jpmzometa/arduino-mbrt - seems to do what it says on the tin.
« Reply #2 on: September 12, 2010, 06:55:36 AM »
Yes!  I have that program and I now have it working. The adruino is fantastic. So is the software. I am working on adding more modbus functions,. I have analog in working now, have constructed a wizard, will post it when done. One small puzzle?  I have to click OUTPUT in the brain editor mod bus setup dialog.
 to read the analog and post it to a DRO.
I also have a pokeys, and it's interesting to compare them. The PWM is much better on the Pokeys as it is 16 bit not 8 bit. I am also looking for encoder and mpg sub routines. For the adruino.  Having lots of fun for $60.
  I wonder if someday I can use the  adruino to take the  place of a smooth stepper ? Of course I cannot write the code, just wondering.
Offline stirling
  •  2,188 2,188
  • UK
« Reply #3 on: September 15, 2010, 06:32:08 AM »
Can't help you there - never used brians  :)
Hmmmmm - doubt it. Remember the serial connection to the Arduino is actually just RS232 over USB (if that's the correct way of putting it) so I don't think you would get the speed apart from anything else - but I'm not sure.
« Last Edit: September 15, 2010, 06:56:47 AM by stirling »
« Reply #4 on: April 08, 2012, 07:46:38 PM »
Is it the serial connection or crystal that matters when it comes to clock speed? What speed does Mach3 require?
Offline stirling
  •  2,188 2,188
  • UK
« Reply #5 on: April 11, 2012, 07:59:00 AM »
My thinking was that both need to be at least considered for a generalized solution. Consider the activity on the serial line as commanded moves get smaller.
Ian
Offline TimGS
  •  108 108
« Reply #6 on: April 19, 2013, 11:49:54 AM »
I would like to use an Arduino Mega 2560 to control the stepper motors, homing switches and extruder/laser output via mach 3 without rewiring to a parallel port.  Understanding that it would take a different firmware load on the Arduino to change it from a gcode interpreter to a hardware controller (similar to the smoothstepper).
Has anyone done this?
Why?  I have two 3D printers and I am building a laser cutter with Arduino Mega 2560 controller.
