Hello
Guest
it is
March 29, 2024, 11:02:33 AM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Third party software and hardware support forums.
LazyTurn
No post of the G-code
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: No post of the G-code (Read 14180 times)
harrison280
3
on:
August 23, 2010, 04:39:25 PM »
Hello,
When i use LazyTurn om my Wondows 7 PC i cannoty get to post the G-code
On my other PC with XP it works fine withe thesame dxf drawing.
The PC calculates the G-code but i cannot post it. Notepad cannot find the document its says as error.
Somebody any idea
Thanks Kees
Logged
Re: No post of the G-code
Reply #1 on:
August 23, 2010, 05:16:45 PM »
Kees,
I can't help since i don't use Windows 7.
But will watch for a reply / answer to you so it can be put in the manual.
Last Edit: August 23, 2010, 05:18:21 PM by RICH
Logged
TOTALLYRC
861
Reply #2 on:
August 23, 2010, 05:36:13 PM »
I just tried it here.
When win 7 gave the error message I said OK make a new file.
Then I posted again to the file just created. The post is completely blank.
It does appear to be calculating the path it just won't post.
Mike
Logged
1stcuts
5
Reply #3 on:
September 02, 2010, 11:13:41 AM »
Hi, Look to see if the posted file (G code) is in the Mach folder with the name you assigned to it.
Bill
Logged
harrison280
3
Reply #4 on:
September 02, 2010, 04:57:50 PM »
Hello Bill,
I tried what you suggested and it works.
Thanks for your help
Kees (Holland)
Logged
1stcuts
5
Reply #5 on:
September 03, 2010, 06:15:37 AM »
Hi Kees,
Your quite welcome. Back in April of this year, (Art's last dedicated block of time) we discovered this
issue with win7. Look at page 139 of the LT general posts for some other suggestions, on how to make
posts to notepad.
Cheers,
Bill
Logged
Reply #6 on:
September 04, 2010, 08:02:33 AM »
Here are some notes from LT page 139. Can someone using W7 fix the text so it provides clear answer to the posting problem.
( make note of the version you are using as i think that the home version won't allow you to run in XP mode......could be wrong as i don't use it )
Logged
harrison280
3
Reply #7 on:
September 04, 2010, 10:17:51 AM »
Rich
I now put a check in the in the box (windows xp sp2 and now the file is visible and i can save it anywhere i want.
It now works good.
Logged
TOTALLYRC
861
Reply #8 on:
September 06, 2010, 09:43:20 AM »
Hi Rich,
Any version of win7 will allow you to run in compatibility mode. What you can't do is run the xp emulator or whatever it is called. Some programs won't run in compatibility mode and need to run in a winXP environment.
I touched up the file as you asked.
I am attaching it so it will help anybody that needs it.
Mike
Logged
Reply #9 on:
September 06, 2010, 09:50:46 AM »
Thanks Mike,
I saved the file such that i will probably never find it later..............at least i know where to look for it here
Logged
Print
Pages:
1
2
Go Up
« previous
next »
