Hello Guest it is April 18, 2024, 02:20:40 AM
Author Topic: No Toolpath  (Read 13075 times)
No Toolpath
« on: August 15, 2010, 01:30:30 PM »
I'm trying to figure out Flash screens on my own (and I have no Flash experience), and can't get a toolpath to display. Even with the finished flash screens, I don't get a toolpath. I also downloaded the Mach Nation .fla, and publish it, and no Toolpath. I tried copying and pasting the toolpath from the beta components, doesn't work.
Can someone tell me how to create a toolpath display in Flash? I think that once I get a working toolpath, I can go from there.
Also, the tutorial video's start on Video #2. I know I've seen #1 before, is it available anywhere?
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
Re: No Toolpath
« Reply #1 on: August 19, 2010, 04:09:51 PM »
Yes the toolpath code has changed since now you can display up to 25 toolpaths:
Acualy this code would be best, place this code on the starting frame( it is a global function and only needes to be seen once)
Code: [Select]
/////////Display toolpath ("TN" is the argument tool to display)////////
_global.gettool = function(TN) {
// X Y positioning
ToolX = getProperty(machscreen_mov, _x);
ToolY = getProperty(machscreen_mov, _y);
// find height width
ToolWidth = getProperty(machscreen_mov, _width);
ToolHeight = getProperty(machscreen_mov, _height);
//Toolpathscreen/////
///Send to mach "TN" is toolpath////////
fscommand("Tool"+TN, "Show");
fscommand("Tool"+TN+"X", ToolX);
fscommand("Tool"+TN+"Y", ToolY);
fscommand("Tool"+TN+"Width", ToolWidth);
fscommand("Tool"+TN+"Height", ToolHeight);
then call on it with
Code: [Select]
gettool("1");
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
Re: No Toolpath
« Reply #2 on: August 19, 2010, 04:11:35 PM »
or simply do:
Code: [Select]
//Toolpathscreen 1/////
fscommand("Tool1", "Show");
fscommand("Tool1X", "100");
fscommand("Tool1Y", "100");
fscommand("Tool1Width", "100");
fscommand("Tool1Height", "100");
Re: No Toolpath
« Reply #3 on: August 19, 2010, 07:03:30 PM »
Thanks, I'll give it a shot.
While I've got your attention. :) In the videos, you have some text files where you copy and paste code for buttons, and LED's and stuff. Are these available anywhere?
I'd gladly pay $25 for a Flash screen manual. :)
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
Re: No Toolpath
« Reply #4 on: August 19, 2010, 08:54:02 PM »
Thank you for the offering, I was hoping that some one else was doing it  ;)
I will talk to Brain and get one made up.
In the mean time use this fla and select rhe objet and copy and past the code.
If you need any help email me.
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
Re: No Toolpath
« Reply #5 on: August 19, 2010, 08:56:25 PM »
also check out :
http://www.machsupport.com/forum/index.php/topic,15603.0.html
I will have TCP code done as well, so you can talk to anything that commmunicates over an IP to/from Mach.
Re: No Toolpath
« Reply #6 on: August 19, 2010, 09:06:43 PM »
Thanks, Jason.
Re: No Toolpath
« Reply #7 on: August 21, 2010, 02:24:58 PM »
The problem seems to be that I get no toolpath with ANY Flash screens. I download the MachNation .fla you posted, and publish it. I can load and run g-code, but there's no toolpath.
So I guess It's not that I don't know how to do it, but why isn't it working?? Any idea? Using 3.42.40
Re: No Toolpath
« Reply #8 on: August 22, 2010, 11:25:57 AM »
OK, I tried it on my Laptop that has Mach 3.041 and the toolpath works fine there. So, is anyone using a Flash screen with 3.42.40? Or is my problem somewhere else?
Re: No Toolpath
« Reply #9 on: August 22, 2010, 11:29:35 AM »
OK, went back to 3.42.20, and it works!!
