Hello Guest it is April 19, 2024, 11:28:40 PM
Author Topic: KX3 spindle running slow  (Read 5798 times)
« on: August 12, 2010, 05:04:50 PM »
Have just installed new KX3 with 5000rpm spindle the problem is that the spindle is running at about 50 % of the speed which is called for it maxes out at 2300rpm I altered the pulley 4 settings to 5000, ran auto cal in function config as the speed ramped up the revs lagged by about 50% I also entered a speed by MDI with same result checked spindle revs with digital rev counter.The cd contained a KX3 5000 profile version R3.041 which I used. Have only jogged other axis & they appear to be working OK. Hasanybody got any ideas please.
Offline kf2qd
  •  148 148
Re: KX3 spindle running slow
« Reply #1 on: August 13, 2010, 10:01:15 AM »
I had a problem with mine when I first set it up. It ran at max speed at anything over 2000 Rpm.
My numbers under Motor Tuning/Spindle are - Stepps Per 1175, Velocity 857.4, Accel 212.76596, Step Pulse 6.
Under pulley 4 I have mini speed 100, max speed 5000, ratio 1.
The number you want to mess with is the steps per number under motor tuning.
« Reply #2 on: August 13, 2010, 02:27:09 PM »
kf2qd
just tried settings worked OK it was within 100rpm checked at 1000rpm steps
thanks Ray
