Hello Guest it is April 27, 2024, 12:44:11 AM
Author Topic: M98 Subroutine Directory  (Read 3988 times)
Offline rcaffin
  •  1,054 1,054
« on: August 01, 2010, 07:38:46 AM »
After some hours of frustration, and then another hour of searching here, it appears that any named subroutine I call must be in the Mach3/SubRoutine directory.
This is slightly anomalous as I can load a main routine from anywhere, but I cannot do that with subroutines. That is, the following does not work for me:
M98 (c:\mach3\gcode\sub.tap)
Would it be possible to have the next release allow the full filename string please? That way I can keep projects separate.
If there is another way to handle this, or if I am just wrong, please advise!
Offline Mc2
  •  31 31
Re: M98 Subroutine Directory
« Reply #1 on: August 02, 2010, 03:44:22 PM »
I ran into the same issue. You can however just locate your sub program at the end of your regular program that is to say:
(Main program here)
G0 X0 Y0
M98 O0100
M30
(After M30 put the sub program with program number. By the way they start with the Letter O not zero.)
O0100
(Lines of code to run when sub program called)
M99
This will keep all sub programs and main program together. If you use the same sub program for other programs you will have to add it in or save sub program to the subroutine's directory. If there is another way, I have not found it.
Jim.
Offline rcaffin
  •  1,054 1,054
« Reply #2 on: August 02, 2010, 06:03:52 PM »
Oh, I know that. I want to use an external file as a subroutine to hold a large number of parameters which are common to several programs. That way, if I alter a parameter, it is automatically altered for every program which uses that parameter file. But it would be nice to have each project in its own folder.
Offline rcaffin
  •  1,054 1,054
« Reply #3 on: April 17, 2018, 12:55:20 AM »
Update, for anyone searching this:
You can have your external subroutine anywhere you like, including in your current directory (c:\Projectdir). For some utterly weird reason, you must prefix the text string with a minus sign to make this work:
m98 (-c:\Projectdir\Project1.tap)
Roger
« Reply #4 on: April 11, 2024, 09:27:55 AM »
Roger, I have been looking for this. Thank You so much, I know years later. LOL
Do I need the parenthesis or no parenthesis?
Thank You again.
Doug
Roger
Offline rcaffin
  •  1,054 1,054
« Reply #5 on: April 11, 2024, 05:50:48 PM »
Yes, you do need the parentheses, AND the minus sign
m98 (-c:\Projectdir\Project1.txt)   or .tap
Macvh3Mill.pdf, section 10.8.7, re M98, option b),
Roger
« Reply #6 on: April 11, 2024, 09:04:16 PM »
Roger, Thank you very much, yes I should read the manual.
I have a guy that work with that found this for me.
I am heading downstairs now to try this out.
Hope I have luck. I will let you know.
Thank You
Doug
« Reply #7 on: April 15, 2024, 07:13:22 AM »
Roger
I know you know it works, but WOW. Thank You so very much for posting this.
Greatly appreciated.
Doug
Roger
Offline rcaffin
  •  1,054 1,054
« Reply #8 on: April 15, 2024, 05:40:21 PM »
Yeah, it's very useful.
My current project has about 20 - 30 components, and is only kept under control by having ALL parameters in one data file. That is really ALL of them. Parameter numbers up to about #480.
Roger
