Hello Guest it is April 24, 2024, 05:06:39 PM
Author Topic: Gearotica testing  (Read 227112 times)
Re: Gearotica testing
« Reply #40 on: December 22, 2010, 03:06:49 PM »
Sent, my friend-
« Reply #41 on: January 29, 2011, 06:40:02 PM »
Is there any good explanation available for the output project page for all the input fields, like depth of cut max dept, etc.
I have a licensed copy of gearotica
I have a gear on my lathe, 42 tooth and about 1.750 diameter (only info I have) that have broken tooth.
That is the gear in the transmission for feeding (goes with the worm gear)
Thanks.
Jeff
Offline ART
  •  1,702 1,702
  • Tough as soggy paper.
« Reply #42 on: January 29, 2011, 08:25:54 PM »
Jeff:
  As yet, just the tutorial on outputs. Hard to say fromt he diagram exactly what you need, but the outputs page woudlnt be
used to match the gear really, just the design. Id design a gear with 42 teeth and play with the module or DP will you find one thats 1.7" in diameter.. thats probably the right gear .. but you can compare the teeth on the design page to try to match it to what you see.
   As to outputs, the depth per cut is 2.5d cuts, thats bascially the gearwidth on a normal gear. If its 4th axis the depth is the root depth, so you dont need to set anything..
Art
