May 25, 2013, 12:58:30 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Third party software and hardware support forums.
| |-+  SmoothStepper USB (Moderator: Warp9TD)
| | |-+  Stop button press loses comm with SS
Pages: 1   Go Down
Print
Author Topic: Stop button press loses comm with SS  (Read 681 times)
kencor1
Active Member
Offline Offline
View Profile WWW
« on: July 20, 2010, 04:55:57 PM »
I am using the current dev version with the new standard screenset and when ever I press the stop button after appx 1 sec it get the error screen that the SS has run out of data.  Anyone know how to fix this?
Tom
Jeff_Birt
Active Member
Offline Offline
View Profile WWW
« Reply #1 on: July 20, 2010, 08:57:51 PM »
I would not use the developent version with the SS. Use the latest lockdown version of Mach with the lates SS plug-in and driver.
Happy machining , Jeff Birt
kencor1
Active Member
Offline Offline
View Profile WWW
« Reply #2 on: July 21, 2010, 07:20:59 AM »
Thanks Jeff, I normally use the lockdown version , I was just trying out the new screenset and it requires the current Dev version.
Jeff_Birt
Active Member
Offline Offline
View Profile WWW
« Reply #3 on: July 21, 2010, 08:17:22 AM »
The development verions are typically made to test a new feature and are not tested for compatibility with all the other things out there for Mach. The downside is that it might or might not work.
Pages: 1   Go Up
Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
