Hello Guest it is April 25, 2024, 10:16:27 AM
Author Topic: I'm in Hog Heaven  (Read 96894 times)
Re: I'm in Hog Heaven
« Reply #120 on: February 14, 2015, 12:04:40 PM »
Thanks Tweakie, but by Old faithful, you mean "The Judge"   :o
« Reply #121 on: February 14, 2015, 07:47:59 PM »
Nah......the 44 old mag.....with mercury filled 240 hp's. Splat!  ;D
« Reply #122 on: February 14, 2015, 08:11:08 PM »
I like the multiple Splat's , ;)
« Reply #123 on: February 18, 2015, 12:26:59 PM »
I have a love-hate relationship with these wedge block tool holders.
Found when I added one that the handle interfered with another one.
So I found the angle wrote a macro and machined 3 new holes 90 degrees apart @ 74 degrees in this case. (that must be... China 75 degree)
Now have this machine configured to be setup as a lathe or a mill (in this case I ran it as a mill using X & Z to feed in and out)
z=x
x=y
y=z
c=a
a=b
b=c
« Last Edit: February 18, 2015, 09:13:53 PM by Ya-Nvr-No »
Offline dude1
  •  1,253 1,253
« Reply #124 on: February 18, 2015, 03:42:15 PM »
how many more axis are you going to add that is a cool looking machine
« Reply #125 on: February 18, 2015, 05:06:37 PM »
Thanks, I still can add two more controllable drives  ;D
here is that macro I wrote, thought others might like to see it or adapt it to their needs.
By changing a couple of variables and making sure where your part hole center line and the hole face is, this will peck at any X Z angle.
https://www.youtube.com/watch?v=I35FEU8EDjk
« Last Edit: February 18, 2015, 09:14:14 PM by Ya-Nvr-No »
« Reply #126 on: February 26, 2015, 05:24:12 PM »
Russ do you recognize  these?  ;)
Made a few, and a few extra so I can get back to that Laser build project. (Thanks again for the extrusion)
http://youtu.be/9i8FNma-OlM
damn poor Photo shows the ID hex turned with a single point tool on the lathe.
Video shows the turning, threading, center hole and cross hole operations.
« Last Edit: February 26, 2015, 05:31:25 PM by Ya-Nvr-No »
« Reply #127 on: February 26, 2015, 06:25:12 PM »
Yes I Do !
IIRC, pretty pricey from Phoenix Mechano.
I was just recently thinking of giving you a bump on that other project, hope to see some progress reports soon.
Sure was good to see someone make good use of that aluminum. I had far more than I would ever need. (famous last words)
Fancy schmancy little machine you got there. A hybrid, mutant, crossbred looking device. Better not make it too smart, it might turn on you one day. (and watch that sweatshirt sleeve)  ;)
Good job, thanks for posting Craig,
Russ
