Hello
Guest
it is
April 25, 2024, 05:49:01 PM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Mach3 under Vista
Windows 7 32bit and Mach 3
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Windows 7 32bit and Mach 3 (Read 31144 times)
Jeff_Birt
1,107
Re: Windows 7 32bit and Mach 3
Reply #10 on:
July 02, 2015, 01:26:46 PM »
External devices such as the SmoothStepper work fine on a 64bit OS. If you are looking to add an external motion controller to an existing machine without rewiring things you could use something like my SSENC-2:
http://www.soigeneris.com/ssenc_2_ethernet_smoothstepper_system-details.aspx
Logged
Happy machining , Jeff Birt
Check out
www.soigeneris.com
ger21
6,295
Reply #11 on:
July 02, 2015, 01:47:46 PM »
Neither was answering your two questions I quoted.
Logged
Print
Pages:
1
2
Go Up
« previous
next »
