Hi all,
Newby here. Reading through the thread, I think the issue I have is that I need a new parallel card that supports the ability to remap to legacy port address i.e. 0x0378, as my device manager settings for my current Parallel card are showing:
I/O Range BC00-BC07
I/O Range B880-B883
I have set the Mach3 Port #1 to read 0xbc00
However I am still unsure which card to purchase as I also think my issue is that the pin out voltage I have measured on my currently installed Parallel ports pins is 3.34V, I have been reading through the specifications on various PCIex cards but they don't specify what the pin out voltage is. Do I assume that if the card supports legacy remapping, it will also provide the old TTL 5v outputs?
Also, I am running Windows10 (32bit mode) on my PC (HP pavilion 7000) Mach3 demo version is loaded and seems to function ok, are there any known issues with running Win10?
