Hello Guest it is April 26, 2024, 06:53:15 AM
Author Topic: Smothstepper and 3D probing plugin?  (Read 5505 times)
Offline Denis
  •  13 13
« on: May 07, 2010, 03:29:59 PM »
I'm newbie in CNC, and in smoothstepper.
Does anyone know if the 3D probing Plugin  works with a smoothstepper?
It doesn't work by me, plugin is enabled, and if I click on the 3D probing menu, nothing happends!
Have someone test it with a smothstepper?
Denis
Re: Smothstepper and 3D probing plugin?
« Reply #1 on: May 11, 2010, 10:46:45 AM »
I'm also interested in this post. I use a SS, but plan to get away from it.
I need to do some probing and was doing my research on probing when I found this post.
Anyone ???
Offline Denis
  •  13 13
« Reply #2 on: May 11, 2010, 11:49:13 AM »
Hi Curmudgeon,
Did you try the probing plugin? Does it works on your machine?
regards,
Denis
« Reply #3 on: May 11, 2010, 08:16:49 PM »
Sorry Denis, I haven't  done any probing yet. Just getting started and doing some research when I found this post.  I kind of doubt the problem is the smooth stepper, but then I'm no expert for sure !
« Reply #4 on: June 11, 2010, 06:24:28 PM »
I have done some probing with SS and It does work if you have your setup done correctly
CRUISER
  Don
Offline Denis
  •  13 13
« Reply #5 on: June 13, 2010, 06:52:55 AM »
Hi Cruiser,
The Probe is working well, only the probing plugin doesn't work by me. I have a 3D probing menu, but I can't go to any setup or routine from this menu.
Is that working well by you?
Denis
