Hello Guest it is April 25, 2024, 03:36:25 AM
Author Topic: Reference routine  (Read 3219 times)
Reference routine
« on: May 07, 2010, 11:29:35 AM »
Dear All,
We have two expensive laser cutting machines that wave been designed and integrated by another company. Both machines are driven by Mach3 trough SS board.
Also, both machines haves C axis as slave to Y axis.
After the reference routine C axis seems to be unslaved. Only Y axis works.
Which is the proper reference routine and which is the proper Verify routine? There is something wrong in SS or in Mach3?
Another thing: G4 doesn't work in ms.
Thank you,
Re: Reference routine
« Reply #1 on: May 07, 2010, 12:22:37 PM »
 I can only help with the dwell.
Select it under config/gen config.
Russ
« Reply #2 on: May 07, 2010, 12:31:39 PM »
Doesn't work with SS driver that i have.
I don't know if it was fixed or no but i saw few posts in this forum regarding this issue.
Seems to be a problem of SS.
Thank you
