Welcome, Guest. Please login or register.
Did you miss your activation email?
May 23, 2013, 06:41:49 AM
Login with username, password and session length
Search:     Advanced search
* Home Help Search Calendar Links Login Register
+  Machsupport Forum
|-+  General CNC Chat
| |-+  Show"N"Tell ( Your Machines)
| | |-+  My Frankenstein
Pages: 1 2 3 »   Go Down
Print
Author Topic: My Frankenstein  (Read 5741 times)
Chaoticone
South Carolina, US
Administrator
Offline Offline
Precision Chaos
View Profile WWW
« on: October 09, 2006, 05:04:08 PM »
Here are some pics of my little Frankenstein. Not much, but I sure do love it being controlled by Mach.
« Last Edit: October 10, 2006, 05:21:15 AM by Chaoticone » Logged
Grin If you could see the things I have in my head, you would be laughing too. Grin
www.precisionchaos1.com
Guest
« Reply #1 on: October 09, 2006, 05:44:29 PM »
Looks good, takes me back to my first conversion of a manual Bridgeport. How do you find it with the knee being the Z Axis? Is the weight enough to take the backlash out of it or have you fitted a ballscrew?
 I was like you and decided to keep the handles on the X and Y as I was adamant that I would use them quite a bit for simple jobs, I was wrong and a nine inch angle grinder came into play as I was too lazy to make up spacer Wink
BTW whats got your coolant hose so excited Wink
Logged
ynneb
Guest
« Reply #2 on: October 09, 2006, 05:59:40 PM »
Yes it does look good.
Could you please do me a favour and make the pictures a bit smaller so they can fit on others screens. Bigger is not necessarily better !
Logged
Chaoticone
South Carolina, US
Administrator
Offline Offline
Precision Chaos
View Profile WWW
« Reply #3 on: October 10, 2006, 04:04:33 AM »
Hood,
    It's the Mach. What can I say, he's in love!!!!!!  Shocked He's changed so much since he meet Mach. They are  just dancing around, all the time, doing frivolous things. Maybe the infatuation will wear off one day and they can put their heads together and do something productive. They sure are having allot of fun now though. I'm pretty sure this is going to be a long lasting love!!!!! Grin
   Yes, the knee is heavy enough to remove any backlash it may have had. No drift,no counter weights, no break and no d_ _ _  speed. Angry 8 in. minute is all I can get on the knee, 130+ on the x and y. I don't think this will be to big a problem though, most stuff I'll be cutting will have a low feed anyway. Spindle is to slow to feed too fast.I'm using 1780 oz.in. steppers on all three axis. The finial drive for the knee is 6-1.  I replaced the lead screw and nut, with high precision ones. I also replaced all the bearings and gears. It is pretty tight. I have .0015 backlash in the knee, .0015 in the y, and .002 in the x.
« Last Edit: October 10, 2006, 07:10:17 AM by Chaoticone » Logged
Chaoticone
South Carolina, US
Administrator
Offline Offline
Precision Chaos
View Profile WWW
« Reply #4 on: October 10, 2006, 06:58:45 AM »
Here are a few cuts.
Logged
chad
Global Moderator
Offline Offline
When the going gets weird, the weird turn pro.
View Profile
« Reply #5 on: October 10, 2006, 12:32:32 PM »
I have a similar machine, I used retrofit components from Elrod machine. He makes a VERY nice quill drive. It is cool in the fact that it can be manually disengaged so you can still use the quill handle when you need to. It is a great company to work with. This would really help with the speed problem in the z. I can get over 300 ipm on all three axis but I have it limited to about half of that as it is just scary at those speeds.
You can see some pictures of our machine here (towards the bottom) http://www.machsupport.com/forum/index.php?topic=627.0
Here is the link to the elrod site. http://www.elrodmachine.com/CNC_Z_Axis_Quill_Drive.htm
Chad
Logged
Chaoticone
South Carolina, US
Administrator
Offline Offline
Precision Chaos
View Profile WWW
« Reply #6 on: October 10, 2006, 02:12:30 PM »
Oh yea, I saw those pics. I want to see that 5 axis monster run. You do good work. I'll have to keep an eye on you. Thanks for the link, I will check it out.
Logged
Guest
« Reply #7 on: October 10, 2006, 02:35:57 PM »
I thought about doing the knee at first but decided to go with the quill as I thought I would probably have speed issues. I ended up using a tiny wee stepper on the quill (260oz/in) with a 3:1 reduction and 5mm pitch  ballscrew, it worked great. Tool changes could be a PITA with the R8 collets being so long and thats where the knee being the Z would be good.
Logged
Chaoticone
South Carolina, US
Administrator
Offline Offline
Precision Chaos
View Profile WWW
« Reply #8 on: October 10, 2006, 03:10:22 PM »
I do like the knee because it has like 15in. of travel. One 1780oz.in. motor would move the knee with a 2-1 gearing, but that was all it would do. I've gotta try to put another stepper on it, Stack or 3 pulley set up just to see. I've never got the torque curve for these motors yet. That will help me make a decision.
Logged
JDolecki
Active Member
Offline Offline
View Profile
« Reply #9 on: October 10, 2006, 09:19:13 PM »
Is that a connecting rod for a harley?
Logged
Pages: 1 2 3 »   Go Up
Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
