Hello Guest it is April 25, 2024, 03:31:57 AM
Author Topic: mach 3 driver test program  (Read 25568 times)
Re: mach 3 driver test program
« Reply #10 on: April 10, 2010, 05:32:08 PM »
Sounds good.
Thanks alot anyway.
Talk to you soon
Regards
« Reply #11 on: April 11, 2010, 02:30:21 PM »
Other problem when the pc turn off is send pulse that can ignite the M3 and M4 at the same time, and trigger a stroke on the motor or burning fuses.
Normally closed contactors cancel the M3 and M4 are not fast enough to protect the shooting of PC.
regards
« Reply #12 on: July 02, 2014, 12:48:46 PM »
Ok, So I looked through the bios with my boss (computer nerd and electronics nerd) but we were unable to find APIC, C1E, or EIST. These were setting people suggested we turn off. What does the DriverTest.exe test? Is it checking the parallel port in the computer, the Mach3 driver, or both together?
Bendan
« Reply #13 on: July 02, 2014, 12:52:52 PM »
It is checking the driver, ie whether or not the computers pulse is steady or not.
The Port itself does not get tested.
« Reply #14 on: June 09, 2018, 11:07:31 AM »
Hi there
I'm Murad, A new comer.
I installed Mach3 in a XP pc, actually going to modify one of my lathe machine to cnc.
However, after installation, from where to find the "mach3 driver test.exe" file? Shall I have to install it separately or automatically it will create the desktop shortcut?
Please help me.
« Reply #15 on: June 09, 2018, 03:46:07 PM »
look in the main Mach3 folder, it should be call DirverTest.exe. You can run it from there or create a shortcut as you wish.
