Hello Guest it is April 20, 2024, 08:20:32 AM
Author Topic: minimum diameter?  (Read 4274 times)
minimum diameter?
« on: April 06, 2010, 11:10:58 AM »
Me again...sometimes when I import a DXF r12 I get to change the rulers to the correct diameter of stock but my profile diameter is way too big and it has a minimum that is larger than my set stock diameter?
I have been all thru the manual but still cant figure it out?
Re: minimum diameter?
« Reply #1 on: April 06, 2010, 09:47:42 PM »
What LR imports is what you have drawn. If you drawing represents a diameter then in the OPtions menu  ( section 5.3 ) you should select diameter mode. Same goes for imperial or metric mode. You can change the stock diameter if you wish with the the penatgons  ( see section 6.2.1)
