Hello
Guest
it is
April 26, 2024, 08:46:18 PM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Support
One on one phone support.
Changing parallel port setting to run Mach3
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Changing parallel port setting to run Mach3 (Read 7302 times)
autostaff
2
on:
April 01, 2010, 08:25:36 PM »
I've built a plasma table with a Probotics 3 Axis kit and I've downloaded the Demo version to try just to see if it is going to work. One of the problems that I'm having is with it communicating with the Driver board and Mach. I was told by Probotics that I need to change the Parallel port setting. Is this true? Or is there some way to set up Mach to work with this. I can't believe that I would have to change the printer port settings to get this to work.
Please help I just want to see it run.
Thanks in advance
Lance
Logged
Re: Changing parallel port setting to run Mach3
Reply #1 on:
April 02, 2010, 09:09:55 AM »
You need to tell mach the address of the parellel port in config>port& pins, so that is what they are probably talking about i am thinking.
Post info on your controller. Till then maybe someone who has same controller will post.
Logged
Print
Pages:
1
Go Up
« previous
next »
