Hello Guest it is April 20, 2024, 01:13:13 AM
Author Topic: trouble importing lazyturn gcode  (Read 4583 times)
« on: April 01, 2010, 11:20:43 AM »
Hello I am trying to use Lazyturn for the first time and can import my
DXF drawing and seem to be able to cam the cut paths no problem and I can generate gcode.
The problem is when i try to open the .tap file in machturn I get a nasty little message saying "bad format unsigned integer line 2"
Anyone run across this one?
Re: trouble importing lazyturn gcode
« Reply #1 on: April 01, 2010, 11:45:48 AM »
See attached
« Reply #2 on: April 01, 2010, 01:14:13 PM »
Rich, You ROCK! that was it...thanks-a-million!!
