Hello Guest it is April 25, 2024, 08:03:53 PM
Author Topic: Error triggered Art code: 1  (Read 9402 times)
« on: March 28, 2010, 09:21:20 AM »
Hi all,
I have this problem with mach3.
Can anyone help?
Tanks a lot.
Re: Error triggered Art code: 1
« Reply #1 on: March 28, 2010, 11:19:09 AM »
Has this just started or is it a new install?
How do you get that, is it just as you try to start Mach?
What version are you running and is it licenced or just a demo?
Have you tried re downloading from Machs downloads page and reinstalling?
« Reply #2 on: March 28, 2010, 02:15:33 PM »
Hi Hood,
I work with this installation about 2-3 years, without any problems.
Some day when I started Mach3  appears this message.
I have buy Mach3 lic. ( for SCULE ARAD)
This messages appears with old installation, and wen I reinstall with new version, this messages appears again.
I remove Mach3 from my computer, and I reinstall with last version  but this message appears again.
Tank you very much Hood, and all,  for any suggestions.
Daniel.
« Reply #3 on: March 28, 2010, 05:18:12 PM »
I will see if Art can have a look as he is probably the only one that will know what the Artcode means.
Offline ART
  •  1,702 1,702
  • Tough as soggy paper.
« Reply #4 on: March 28, 2010, 05:50:20 PM »
Hi:
 Does it happen with Mach3Turn? Or how about trying a new blank profile?
Art
« Reply #5 on: March 29, 2010, 02:15:35 AM »
Hi Art,
It happen with mill Mach3.
 Mach3Turn works, and Mach3Plasma works only x and z axis, y don't work .
Only Mach3Mill and new mill profile appears this message.
Tanks Moraru Daniel.
Offline ART
  •  1,702 1,702
« Reply #6 on: March 29, 2010, 09:56:51 AM »
Hi:
  Hmm, zip the xml profile and post it here and Ill see if I can find the problem, must be a setting somewhere..
Art
« Reply #7 on: March 29, 2010, 05:05:03 PM »
Hi Art,
This is all files .xml from my Mach3 profile.
Tanks,
Daniel.
Offline ART
  •  1,702 1,702
« Reply #8 on: March 29, 2010, 06:48:41 PM »
Hi:
  Im afraid it works fine here.. Mach3mill.xml does anyway.
I notice you have a file with no name ".xml" , delete that file and any xml's you dont use and see if that helps..
Art
« Reply #9 on: April 02, 2010, 11:29:03 AM »
Hi Art,
I solve problem, I remove all mach3 components from my computer and I reinstall mach3.
Until now mach3 run OK.
But I don't know why the message appeared.
Tanks for advices.
Moraru Daniel.
