Hello Guest it is April 23, 2024, 10:23:34 PM
Author Topic: Changing image file  (Read 11586 times)
Changing image file
« on: March 16, 2010, 09:40:21 PM »
I cannot change the image file for either buttons or LEDs. If I double click in the field nothing happens. What am I missing?
Re: Changing image file
« Reply #1 on: March 16, 2010, 10:08:00 PM »
I am also unable to change LED properties, like color or blink
« Reply #2 on: March 17, 2010, 04:01:33 AM »
Hi Ron,
how do select the element, what are your settings? When you select the item, does the frame appearance change?
Klaus
The brain isn't a soap, it doesn't shrink when used.
« Reply #3 on: March 17, 2010, 08:12:06 AM »
I simply click on the element I want to edit. It then shows the black handles, and the property dialog fills up. I can change the OEM code, but none of the other properties. Ive tried clicking on both the name and the property, also double clicking each, and right clicking.
I just tried removing machscreen completely and reinstalling but it still works the same.
« Last Edit: March 17, 2010, 08:16:45 AM by Ron Ginger »
« Reply #4 on: March 17, 2010, 08:49:17 AM »
Ron see the pic
Double click in the path box to set the path, another box will open
Phil
« Reply #5 on: March 17, 2010, 10:10:41 AM »
Thanks, but that is exactly what I am doing. It does not open the box to make an edit. The only field I can change is the OEM code. On LEDs I cannot change the image file or the color or the blink property. On buttons I cannot change the file.
« Reply #6 on: March 17, 2010, 11:39:31 AM »
Hi Ron,
could you please send me your set file and tell me which element on what page you want to change the property.
EDIT: The easiest way is do a "project export".
Klaus
« Last Edit: March 17, 2010, 11:45:48 AM by Klaus1311 »
« Reply #7 on: March 17, 2010, 11:57:39 AM »
This happens to any .set file I try- even the 1024.set
« Reply #8 on: March 17, 2010, 12:23:42 PM »
Hi Ron,
I'm using version V1.40.a and it all works like it should.
Try to delete the registry entries. To do that finish MachScreen and start regedit. Move to HKEY_CURRENT_USER\Software\KD_soft and delete  the complete entry "MachScreen". The next time you start MachScreen it will take the default settings.
Klaus
« Reply #9 on: March 17, 2010, 01:53:23 PM »
That did it!
Thanks for the help
