Hello Guest it is April 25, 2024, 09:19:05 PM
Author Topic: Window select after screen scroll  (Read 4233 times)
« on: March 14, 2010, 07:03:49 AM »
Klaus,
The window select function loses track of the object position after screen scroll. Causes slight inconvenience when designing larger screens on a small monitor. Can it be fixed?
Zafar
Re: Window select after screen scroll
« Reply #1 on: March 14, 2010, 07:18:53 AM »
Hi Zafar
does this happen with version V1.40? If so, could you please give some more info, an example would be helpfull
Klaus
The brain isn't a soap, it doesn't shrink when used.
« Reply #2 on: March 14, 2010, 09:16:41 AM »
Klaus,
This has been happening with all the versions of Machscreen. Here are two sample snaps. In image1 the window selects the right objects which are lying under the window. This is when the window is not scrolled in any direction. Now I scroll the window down. The image2 shows that the window is selecting the object which were in that position before scrolling.
Zafar
« Last Edit: March 14, 2010, 09:36:29 AM by zafarsalam »
« Reply #3 on: March 14, 2010, 10:08:36 AM »
Hi Zafar,
this is only an issue, if "Select only complete enclosed" is not checked. I sent you a new version per email for testing.
Klaus
« Reply #4 on: March 14, 2010, 10:45:37 AM »
Yep. It's fixed now. Thanks a lot Klaus.
Zafar
