Hello Guest it is March 28, 2024, 04:45:57 AM
Author Topic: crashing machscreen  (Read 4801 times)
crashing machscreen
« on: March 12, 2010, 01:40:27 PM »
I have again done something to my screen set that causes machscreen to crash. It will draw the screen, open the dialog box for the controls, write a single number '1' then hang for a few seconds, then crash with the 'send report' box.
This is repeatable. I reinstalled 1.39c
The set will open OK by mach and by screen4
The .lset is attached
Re: crashing machscreen
« Reply #1 on: March 12, 2010, 02:13:32 PM »
Hi Ron,
I can't reproduce this issue. When I load your screen, I'm missing some bitmaps (line.bmp, transparent.png, jogcont.png, jogstep.png). Could you please give some more info:
your settings,
could you please send me the files of a "project export"
you reinstalled 1.39.c , which one did you use when machscreen crashed?
Klaus
The brain isn't a soap, it doesn't shrink when used.
« Reply #2 on: March 12, 2010, 03:38:16 PM »
I was using v1.39c. I just tried a re-install to see if it would help.
It was jogcont.phg and jogstep.png that I had just added and was testing.
What is a 'project export' ?
I used screen4 to delete the 2 new pngs and then tried to open it with machscreen and it crashes in the same way.
thanks for the help,
« Reply #3 on: March 12, 2010, 03:49:22 PM »
Hi Ron,
load your set-file, I hope the screen loads. Select menu file-> project export. Create a new dir, click ok to start the export. Copy the files from your selected dir send them to me. If the "project export" fails, please send me the bitmap files.
Klaus
« Reply #4 on: March 12, 2010, 06:21:16 PM »
I cannot get the report- the program crashes just after drawing the pg 1 image and before it completes writing the dialog box with all the edit functions.
Attached are the 4 bit maps
