Hello Guest it is April 19, 2024, 05:33:43 PM
Author Topic: Really odd problem  (Read 3422 times)
Really odd problem
« on: March 12, 2010, 11:39:10 AM »
I need to cut a path for inserting an o-ring. It is extremely simple, but my toolpath on the machine computer is not the same as my g-code. I drew it up in Bobcad and generated a g-code. The simulation works correctly. When I load it in mach3 on my office pc it works properly. My pc's are on a network and I load it in mach3 on the machine pc I get a different toolpath. I have regenerated the program and also created a different program and it still does the same thing. I am attaching a dxf that shows the difference.
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
Re: Really odd problem
« Reply #1 on: March 12, 2010, 01:23:35 PM »
Your IJ mode is set differently on the two computers :)
Happy machining , Jeff Birt
« Reply #2 on: March 12, 2010, 04:53:59 PM »
I am not familiar with that. Can you explain?
« Reply #3 on: March 12, 2010, 05:06:32 PM »
Config menu then General Config page second column about 1/2 way down you will see I J Mode, it can be Abs or Inc, change it to the way it is on your computer that is good.
« Reply #4 on: March 12, 2010, 05:23:49 PM »
That was it. Thanks
