Hello Guest it is April 25, 2024, 01:14:50 AM
Author Topic: Huanyang VFD controller plugin  (Read 581160 times)
Re: Huanyang VFD controller plugin
« Reply #340 on: February 06, 2014, 08:36:58 AM »
Aha, so on my board I have a DB9 connector that is an RS232 port. I'm guessing then that the pins with the A,B,GND and VOD are the 485? Which means I connect the USB to my computer, and then the R-/R+ pins from my VFD to the A/B pins on my converter board. Sound about right? Thanks for the help guys This is the one I have:
http://www.ebay.com/itm/PC-USB-to-RS232-RS485-UART-TTL-Signal-Converter-/360850506092?pt=LH_DefaultDomain_0&hash=item54045dc16c
« Reply #341 on: February 06, 2014, 09:16:47 AM »
Yes, A&B and Grd are the 485 and they connect to the VFD.
Let me know how that little converter works out.
Richard
« Reply #342 on: February 06, 2014, 09:19:04 AM »
Be sure to set your jumpers to 485 on the USB to 485 converter.
Richard
« Reply #343 on: February 06, 2014, 09:21:33 AM »
good call. Is it obvious what the jumper configuration is? It didn't come with a manual.
« Reply #344 on: February 06, 2014, 01:07:11 PM »
There is a transmit and a receive section of the jumpers. I'm guessing that if I'm using USB -> converter -> VFD  I should have the receive jumper set to 232, and the transmit jumper to 485? Thanks again for the help guys.
« Reply #345 on: February 06, 2014, 01:24:27 PM »
Both go to  the 485 jumper pins.
« Reply #346 on: February 19, 2014, 10:46:24 PM »
I have been running the HangyangVFD plugin by Matty Zee on my CNC for the past year without any problems. I recently had a (Blue Screen of Death) from my Windows XP operating system and had to completely reinstall everything. I got everything working again but cannot get the Hangyang driver to be recognized by the Mach3 software. I get the following errors when I load Mach:
Plugin DLL Defective. Reload.
Then
HuanyangVFD.dll-Defective Plugin found..ignoring..
I cannot see the plugin at the Mach plugin config screen. I tried re-downloading the driver and erasing the old one but no dice... Anyone know how I can fix this???
I am running Mach3 version: R3.043.022
I am current on Windows XP service packs and all updates.
Thanks in advance on assistance. Need to figure this out fast as I have a couple jobs on hold because of this issue.
« Reply #347 on: February 19, 2014, 11:04:44 PM »
Did you happen to remember to download the VC 2008 redistributables?
http://www.microsoft.com/fr-fr/download/details.aspx?id=5582
Richard
« Reply #348 on: February 19, 2014, 11:06:48 PM »
Richard
Yes, I reloaded these.
« Reply #349 on: February 19, 2014, 11:08:16 PM »
How did you make out with the 485 converter and the VFD?
