Hello Guest it is March 28, 2024, 07:32:06 AM
Author Topic: Huanyang VFD controller plugin  (Read 578342 times)
Re: Huanyang VFD controller plugin
« Reply #270 on: August 31, 2011, 01:49:28 PM »
hi my first post and problem.
I have  2.2kw spindle+vfd and it is connected via usbrs485 adapter to the spindle (as usualy)
spindle starts normali at the rpm that I want but when I want tu stop it it does not stop eaven mhit E stop and I get an error window.
can somebody say something to this .
tnx
If I click switch to...    start opens
If I click retry nothing happens the same windows open agen
« Last Edit: August 31, 2011, 01:51:02 PM by some3 »
« Reply #271 on: August 31, 2011, 01:58:55 PM »
i have the same problem.
« Reply #272 on: September 01, 2011, 07:14:28 AM »
and I forogt my pc also does not want to shut down after this error apers :(
« Reply #273 on: September 09, 2011, 06:48:31 AM »
Received my rs-485 converter and was running my spindle through Mach 3 in less than 30 minuets thanks to this thread!!! I came across a few bugs that have to be worked out but spindle on/off and spindle speed works great. Thanks for the great plugin Matty!
« Reply #274 on: September 10, 2011, 09:25:44 AM »
I think I discovered what's causing most of the users of this plugin problems. If your at the point where Mach is communicating( pd001=2 pd002=2) with plugin and problems begin with start of spindle, than go to your ports and pins/ inputs and disable( mainly Estop and limit switches or any active high signal Mach is continually searching for) all for testing.
I think most will find everything working without a glitch and this is where the trouble is. If your at this point post back and we can discuss my work around or a possible fix.
BTW this is the RS-485 converter I'm using, and it cost less than $6.00
http://www.ebay.com/itm/190539776031?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
« Reply #275 on: September 16, 2011, 11:39:09 AM »
Which one did you use and anyone tried this one?
Ebay  280710974429
Nosmo
« Reply #276 on: September 16, 2011, 01:13:00 PM »
Ebay  280710974429
Nosmo
[/quote]
The link is in post, here it is again.
« Reply #277 on: September 16, 2011, 02:38:49 PM »
I see, that is RS232 though and I am looking for USB-RS485.
Thanks.
N.
« Reply #278 on: September 16, 2011, 03:51:57 PM »
Oh sorry, I guess I was lucky to have a serial port on my comp. I think any converter to RS-485 should work like Matty said in the beginning of thread. I suspect the problems some were having with this plugin had nothing to do with which converter they were using or electrical noise.
« Reply #279 on: September 24, 2011, 03:04:55 PM »
Does anyone that has been monitoring the data able to clarify the functions in the Data string?
The Chinese manual does not appear to show anything on the RS485? I found a one in Word that seems to have errors.
 The main question I have is based  on what I have so far is that the data string consists the following:
1st byte VFD add, 2nd byte read/write/freq func, 3rd byte the data length followed by the actual data bytes, lastly the CRC.
What indicates the individual parameter addressed?
  Nosmo.
