Hello Guest it is April 18, 2024, 12:13:29 AM
Author Topic: Huanyang VFD controller plugin  (Read 580065 times)
Offline DMBGO
  •  201 201
  • Time is the same in a relative way
Re: Huanyang VFD controller plugin
« Reply #150 on: October 31, 2010, 06:33:31 PM »
Normal PC serial poprts are RS232 ports, whereas the VFD needs a RS485 port. If you look back through this thread you will see some discussion on various options for converting from RS232 to RS485.
Or, just google or ebay RS485 converter
David
« Reply #151 on: October 31, 2010, 06:38:14 PM »
yeh i have just ordered an adaptor on ebay just thought i might be able to work b4 i got the adaptor
Offline mikie
  •  18 18
« Reply #152 on: October 31, 2010, 07:33:59 PM »
The VFD uses RS485 and the interface from your PC is RS232. They are incompatible.
You need to either add an RS485 DB9 card or just use the USB interface to drive the RS485.
« Reply #153 on: November 01, 2010, 06:21:21 PM »
hi there guys
just wondering if anyone might be able to help me ..
when my VFD spindle is running my laptop mouse is all over the place and wont work .. but as soon as its stopped and the mouse works as per normal ..
do i need have to earth / ground something ? or a filter ? or something ?
thanks
Justin
Offline DMBGO
  •  201 201
« Reply #154 on: November 01, 2010, 07:24:41 PM »
Sounds like you need an EMI filter on the incoming power to the VFD, although if the mouse is your only issue, I'd try a different mouse first. A mouse is cheaper. It might just be that you have a poorly shielded mouse!
You can get EMI filters on ebay
David
« Reply #155 on: November 01, 2010, 07:30:26 PM »
hey Dave
thanks for your quick reply mate
sorry when i meant mouse i meant the internal touch pad on the laptop .. ok i'll look for a EMI filter (are they easy to install) ?
thanks
Justin
Offline DMBGO
  •  201 201
« Reply #157 on: November 01, 2010, 08:14:16 PM »
Yes, I think some are better than others, the one you mentioned is only 6 amps, which may not meet the current requirements of your VFD, try this one
http://cgi.ebay.com.au/EMI-Filter-Variable-speed-AC-drive-/320608802271?pt=AU_Gadgets&hash=item4aa5c615df#ht_500wt_1156
I recently bought 2 similar than these from the states and paid about $40.00 each, so this is a good price, and is designed for an AC drive.
David
« Reply #158 on: November 01, 2010, 08:20:21 PM »
Hi Dave
thanks for that :)
so i just wire it between the AC input cable and the VFD ?
easy !!
thanks mate
nice work
Justin
Offline DMBGO
  •  201 201
« Reply #159 on: November 01, 2010, 08:24:34 PM »
If you are unsure about the wiring, get a sparky :)
David
