My VFD also had no chip. I got 5 MAX485CSA from ebay
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=290463383670 shop icmarket2009 £1 each. Not too hard to solder it in place, very small and my eyes aren't what they were for close up work
tinned the pads used tweezers to place and get it sat on all the pads and held down with the tweezers and just dabbed the legs on the pads.
Plugged the sucker in, installed the plugin in Mach, enabled it, programmed the VFD with
PD001 2 commands
PD002 2 frequency
PD163 1 VFD address
PD164 1 Baud Rate 9600
PD165 3 8N1 RTU
as per instructions
and tadaaaa.. nothing..
in the plugin config it just showed 99 in the PD001 and PD002 lines. ahhh
swapped my cables, tried again, 99. re-programmed FVD PD163 with 2 and changed plugin config VFD address to 2
nothing.. 99
swapped my cables back.... got a 2 in PD001 and PD002
hit the spindle start and got.. nothing, went into spindle calibration and still nothing.
loaded up some g-code set some safe zero's and hit start. IT'S ALIVE!!! 2460rpm shown on VFD for 2950 on Mach.
reset max revs on VFD P0144 to 3000 now getting 2949 rpm on VFD.
not haing used Mach controlled spindle before it was just set for zero rpm that had been the problem since I got the 2's showing in the plugin config.
yehaa.. so solder away, all should be shiny
