Hello Michael and Mark,
Well not much luck at the moment and as with everyone finite time we can spend on these problems due to work commitments.
Tried to talk with VFD with spindle talker but no luck crashes out or does nothing, same with modbus on Mach3 well for me anyway.
As I said getting same replies from VFD with both G and F versions so know unit is replying at the moment just using Mack3 to switch spindle on and off and setting speed manually.
As soon as I have set up my new machine hopefully will find time to do some more work on this.
Mark,
Since your machine is working would you mind monitoring commands you send, Start stop etc and replies from your VFD so I can pass on a comparrison to my supplier as I buy lots from them maybe we can get an answer?
BK.
