Hello Guest it is April 26, 2024, 11:30:22 AM
Author Topic: Huanyang VFD controller plugin  (Read 581820 times)
Re: Huanyang VFD controller plugin
« Reply #310 on: November 14, 2012, 05:56:00 AM »
Hi shobley,
maybe you're facing the same problems as I.
That's why i wrote my own plugin. (subject: A new Huanyang VFD plugin)
Some  people have tested it and it seems to work pretty well.
Maybe it could solve your problem dealing with bad RPM.
Seb
« Reply #311 on: November 18, 2012, 07:13:09 PM »
pls. send anew link for bay the  RS485 communication port.
thank you
« Reply #312 on: January 19, 2013, 09:12:43 PM »
I obviously haven't read all the posts in this section but wonder if anyone can help me?
I recently bought a Huanyang HY03D023B inverter, which is a 220v input 3.0 KW output VFD.
I could not get it to work, and told the supplier in China that it was a dud. After many days of measuring and them assuring me that it was a minor problem that they could fix easily, they finally said that they couldn't fix it and that they would send me a new inverter (I have to pay another $35 freight >:(.
The thing that is wrong with it seems to be nothing at all on the output side. It measures very high resistance between all terminals:
The resistance measurements are:
U-V = 4.7 Megaohms         (4M7)
U-W = 12.44 Megaohms     (12M44)
V-W = 4.82 Megaohms         (4M82)
and then, when power is applied:
Measurements across the U-V terminals was 10.6v, Then after pressing start it was 11.1 then after pressing stop it was 10v
Measurements across the U-W terminals was 4.3v, Then after pressing start it was 4.0 then after pressing stop it was 2.6v
Measurements across the V-W terminals was 8.5v, Then after pressing start it was 8.3 then after pressing stop it was 10.6v
As soon as I press the start button I get a fault dL which according to the manual is an output short circuit.
Their suggested course of action for this fault is:
1) Check whether the connection wire of the motor has a short circuit. (The motor is not connected)
2) Check whether the insulation of the output wires is good. (No output wires attached)
3) Send for repair.
So, does anyone have a circuit diagram for this inverter, or better still can anyone advise me what component has failed?
The manual also says that the VFD is fuse protected. I cannot find a fuse anywhere in the box.
Your replies would be much appreciated.
Jeremy Robert (Bob) Willson
« Reply #313 on: January 25, 2013, 03:01:27 PM »
Hello! I use this plugin file HuanyangVFD.dll but will not lower a 7200 RPM
I write s 7200 or lower then the RPM not lower a 7200 RMD what's wrong
« Reply #314 on: February 16, 2013, 03:07:52 PM »
Hello,
I have the plugin here on the internet and wanted to try this happy.I have therefore bought a USB to RS485 adapter, installed, configured and tested plugin.
But as soon as I press spindle start or stop, or change the speed, freezes my Mach3 a briefly.
Have been various attempts, but no success.
Mach3 version:
Version R3.043.066
With German Schmidt screen.
Would be grateful for any tip.
greeting
Udo
P.S. Sorry, my English is bad, that's why a translator = /
« Reply #315 on: February 16, 2013, 05:00:01 PM »
@Daywalker2003,
May have some explanation, but not sure!
This plugin is using .net framework. This framework consumes some CPu and  may lead to brief freeze on 'small' (in term of power) computer.
I have written another plugin, in C++, which aims at consuming less CPU.
Maybe you could try it...you'll find the thread  by looking for "A new Huanyang VFD plugin" on this forum.
« Reply #316 on: February 27, 2013, 04:41:24 PM »
If not, I hope they didn't lock the code on the processor, I may be able to read the from good and transfer to the bad.
Has anyone determined what uC/dsp type for U7?  Your post suggests this may be
known.  I doubt the code would be unlocked however.
« Reply #317 on: April 13, 2013, 11:43:33 AM »
we're using this converter:
DELOCK Adapter 1 x USB 2.0 zu RS-422/485 Seriellen
http://www.delock.de/produkte/G_62406/dokumente.html?setLanguage=en
For troubleshooting we're using this tool:
Modbus Tester
http://www.modbus.pl/node/10
The HY01D523B responses with "00"
And the plugin won't work.
« Reply #318 on: April 14, 2013, 06:47:05 AM »
Microsoft Windows 7 Professional (32bit)
Mach3 R3.043.066
« Reply #319 on: April 14, 2013, 06:51:47 AM »
ftser2k.sys
FTDI Ltd.
2.08.14 built by: WinDDK
ftcserco.dll
FTDI Ltd.
2.01.03.1 built by: WinDDK
ftserui2.dll
FTDI Ltd.
