Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portuguese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 18, 2013, 06:11:43 AM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
dspMC/IP Motion Controller
(Moderator:
vitalsystem
Plugin to load a file of points direct to DSPMC for High Speed Machining HSM
Pages:
1
Go Down
« previous
next »
Author
Topic: Plugin to load a file of points direct to DSPMC for High Speed Machining HSM (Read 3051 times)
piv
Active Member
Offline
on:
February 06, 2010, 12:12:20 AM »
Ive been discussing trajectory planning with Art in the Tempest planner thread. The DSPMC offers the possibility of really high speed trajectories. I am looking for a way of bypassing the Mach trajectory planner, probably by way of either a plugin or stand alone program that can load a file of points directly to the DSPMC. Im looking for anyone else interested in HSM, fast contouring, pre planned trajectories, good chip load control and anyone with info or ability or advice to help me get this sorted out.
piv
Active Member
Offline
Re: Plugin to load a file of points direct to DSPMC for High Speed Machining HSM
Reply #1 on:
February 07, 2010, 03:09:39 AM »
Rufi from VitalSystems DSPMC is going to help me with this. I will let you know how it goes.
Karl W
Active Member
Offline
Reply #2 on:
January 10, 2012, 07:05:19 AM »
piv what happened with this? Thanks, Karl
piv
Active Member
Offline
Reply #3 on:
January 10, 2012, 06:52:42 PM »
Got the plugin and am in the process of writing a trajectory planner to test it out properly.
Karl W
Active Member
Offline
Reply #4 on:
January 10, 2012, 09:20:11 PM »
I just downloaded the Sept 29 version of Tempest from the other thread and tried it out on a 3D pocket. It was pretty much a no-go. Stopping and starting at what seemed like a million short segment curves. I had hoped for more but the benefit seems limited to 2D applications, unless I missed something.
I have a pretty bendy alu extrusion gantry router. It can fly through that pocket at 60ipm in regular Mach with MDF. I was hoping for a software fix that would allow me to let it rapid at high speed, but I get too many random jerks at the beginning and end of toolpaths to let it fly. So I override the rapid rate from 500 down to something like 100ipm, set the acceleration with jogs and then it seems to go OK.
Eventually I would like to build a steel servo-driven machine with proper slides etc, but this is a good learning machine. I am making Moth foils with it - see what you started back in 2000? Figured I could pay for a cheap router pretty easily by making a few molds.
Who knew mothing would drive me to CNC? =:-)
Anyway I have a welder and a flat granite work table so I might just draw up the next machine in Solid Works and start to weld up the major components, figuring to get it together over time. Perhaps by then you will have a plugin for the DSPMC worked out.
I have to say I like the idea of using machine physics to determine the feedrate at any point on the toolpath. But I fear I don't know enough about it to be of much help. I saw you were mentioning the 1ms interval and trying to put those points on the toolpath; obviously if it knows where it has to be 1ms in the future and knows how far it is to that point, it can accelerate the proper amount, but I need to learn more about G code modes to understand what you are up to more fully, and understand why 1ms is the desired interval.
Cool project. Thanks for sharing.
piv
Active Member
Offline
Reply #5 on:
January 11, 2012, 12:05:45 AM »
The 1ms interval is because that is what the DSPMC is expecting, although it could also work at 0.2ms but its not set up for that from Mach yet. Its called the "interpolation cycle". Trajectory planning is not easy because because you have to work out the accelerations over an arbitrary path, for both speeding up and slowing down. But Ive got a way figured out that should work, its kind of half programmed now and it will also let me do RTCP for five axis machines, or any other kinematics required.
Where are you Karl? Moths are a good challenge.
Mould making with short G code segments is a challenge. Even expensive controllers can and do have problems. At the end of the day, the things needed are a rigid machine with high natural frequencies and high stiffness and a control system that looks ahead and plans a decent trajectory that takes advantage of the machines acceleration.
I am now machining foil moulds from aluminium and steel on a machine that weighs 6 tons. I started carving wood centreboards using a table saw and hand plotted NACA foils when I was a kid 30 years ago. Apparently I am still a kid, just the foils are better.
Karl W
Active Member
Offline
Reply #6 on:
January 11, 2012, 10:31:52 AM »
Yes I am a late starter at 40. I am in LA. Better late than never as they say!
I just love the predicting acceleration bit. It seems like there would be some artificial intelligence way to do it; start off slow, put a six axis MEMS sensor on it, run it around a few toolpaths, repeat. Maybe no easily accessible solution though. Might be worth a literature search.
Doing it from the toolpath seems like a lot of fun too, and more logical.
Someday I will have a "real" machine! Until then, I will confine myself to learning on something less expensive.
piv
Active Member
Offline
Reply #7 on:
January 12, 2012, 08:49:35 AM »
My interest is in high end high performance machining with high stiffness and high acceleration. Interestingly the trajectory planning requirements are similar for high end and low end machines but for different reasons. On high end machines the machining time and accuracy of complex surfaces is most influenced by the available acceleration. On low end machines the dynamics and stiffness are low and you need gentle acceleration and smooth motion so that you dont excite vibration in the structure, even at low feed rates.
I want to get to trajectory planning that will consider all of the limitation of the machine, not just the acceleration of the programmed axes. With five axis machines the acceleration and velocity of the physical axes (after transformation) is also important.
Rhino is a good starting point. Have a look at MadCam. Rhino has a good API, so you could get closely spaced trajectory points for both the tool tip and the physical axes (for machines with say 4 or 5 axes) directly from the surfaces and taking into account the local derivatives. Its a good approach, but I need a solution that will work with other existing CAD-CAM packages.
Karl W
Active Member
Offline
Reply #8 on:
February 10, 2012, 01:14:51 AM »
I am actually using MadCAM. It works pretty well for what I do.
I have been doing a fair bit of reading scholarly articles on NURBS machining. Mainly this is driven by the trajectory planning issue - lots of papers are being written about it. Clearly defining the path as a NURBS curve lends itself more to good trajectory planning than defining the path as a bunch of connected segments.
I emailed Joakim and he is considering adding NURBS toolpath output to the next version. This would be a huge step forward, because none of the other low-end CAM programs can generate that code, which seems to be limiting the developers.
Of course there don't seem to be many controllers that will accept the NURBS gcode at the moment, but that is changing. EMC has a biarc interpolation method in 2D now apparently, and some other guys claim to have it working in 3D. But I haven't seen any video, other than a short one by Martin Duzi in 5 axis EMC, and he is using his own HAL interpolator to generate the toolpath from a regular line/arc toolpath.
In the interim, I think I need to mess around some more with the CV settings and the Tempest planner. When doing concentric surfacing paths, for instance, the jog from the end of one lap out to the start of the next one is too steep, which sets up resonance. There has to be a way to slow that movement down without slowing the rest of the toolpath.
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> CS-Lab
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Mach3 Wizards
=> Newfangled Mill Wizard
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
