Hello Guest it is April 27, 2024, 12:14:56 AM
Author Topic: 4 axis screens for 800x600 display  (Read 56927 times)
Re: 4 axis screens for 800x600 display
« Reply #50 on: May 12, 2010, 11:15:59 PM »
Thanks.
and also i tried your screen,the spindle/ATC page is complete blank.and the diagnostics page font is too small.imean input and output text isl small.
will be waiting for the JOG screen.mine is touch screen.always wanted to have a separate screen with big buttons and with all jog settings (step and velocity etc).
« Reply #51 on: May 13, 2010, 12:25:19 AM »
Give me a week. I am busy these days with designing a custom 6 axis screen.
Zafar
« Reply #52 on: May 31, 2010, 11:21:12 AM »
i would like to suggest some more modifications
for touch screen and 3 axis router,i would be much better if you remove 1st page (setup) and spindle page.add the MDI command line to your existing 3rd page.
and place the spindle override an feed rate override in the same page.
diagnosis page is not that important but Jog screen with Big buttons are very important.
1024 screen set with Xbox 360 support
« Reply #53 on: June 24, 2010, 11:15:08 PM »
Here's a screen set which I am using at my shop floor. It has Xbox 360 hand held controller support. I use this controller with an excellent plugin programmed by Lee Davis. The macros used with these screens are included in compressed file. The config screen for Xbox 360 is also included. I use the back and start buttons for activating the macros. The back button loads the Xbox screen on which X0, X/2, Y0, Y/2 and Z0 are selectable with the back button on Xbox. The Start button executes X0, X/2 .... commands which zeroes and halves the X axis. Similar functions for Y and Z axes. Basic idea is that I can locate and center a job on the machine bed without the need to reach out to the keyboard on the control panel. Very useful for large machines.
For installation, uncompress the files in Mach3 folder. The digital-7.ttf font file goes into the windows/fonts folder and in the Function Cfg's/Fonts menu in Mach3 select digital-7 as the font for DRO's to get the desired effect. Screenshots at http://www.machsupport.com/forum/index.php/topic,12753.msg100682.html#msg100682
Zafar
« Reply #54 on: August 04, 2010, 06:14:19 AM »
Here is the complete 1024x768 screen set. It is similar to the previous KC05 except that it has the jogging screen which is suitable for touchscreens. Follow the instructions in previous posts for installation.
Zafar
« Reply #55 on: February 06, 2013, 06:10:43 PM »
Hi  Zafar ! I really liked your screen set for 800x600 ! I have some tablet with 8" screen 800x600 . But , what happend on my tablet is this
Any advice ?
« Last Edit: February 06, 2013, 06:13:11 PM by Unikus »
« Reply #56 on: February 06, 2013, 09:17:24 PM »
Any advice ?
It can't read the LED images in the bitmaps folder. Make sure you have copied the contents of the bitmaps folder to the tablet.
Zafar
« Reply #57 on: February 07, 2013, 02:07:37 PM »
Zafar,thank you very much ! it was my mistake. All greate! But I think here is absent the "Settings" screen,because it is very usefull . Is it possible to add it ?
« Reply #58 on: February 07, 2013, 08:56:00 PM »
It is very old project and I lost the Realdraw files for it's screen design in a hard disk crash. I am afraid you'll have to bear with what it is.
« Reply #59 on: February 08, 2013, 05:17:07 AM »
Or, you could always play with the screen designers and add your own  ;)
