Hello
Guest
it is
March 28, 2024, 04:42:12 PM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Hesitation in jog, G0 upgrade problem
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Hesitation in jog, G0 upgrade problem (Read 3434 times)
aljolley54
2
on:
January 13, 2010, 11:53:33 PM »
I just upgraded my router from Mach3 1.84 to 2.66 now when I jog both the x or the y there is a hesitation. The Router will move about 6 inches, slow way down to almost zero, then accelerate to the correct velocity for the rest of the move. This also happens in G0 moves. Did not do this before the upgrade?
Logged
Carnoustie, Scotland
Re: Hesitation in jog, G0 upgrade problem
Reply #1 on:
January 14, 2010, 03:38:19 AM »
can you attach your xml please.
Logged
Mac The Knife
13
Reply #2 on:
January 14, 2010, 09:16:01 AM »
Sounds like backlash compensation. There is an additional setting somewhere in Mach to speed up the process.
Logged
Mstcnc
19
Reply #3 on:
January 14, 2010, 11:32:14 AM »
You need to check "Shuttle acceleration" value, if too big it will make backlash act as you noticed. I have servo motors and can use value like 0.01 but stepper maybe need more, depends your machine....
-Mstcnc
Logged
aljolley54
2
Reply #4 on:
January 14, 2010, 03:30:40 PM »
Thanks. The problem was in the backlash and shuttle speed. Not sure I have it optimized but do have it working.
Logged
Print
Pages:
1
Go Up
« previous
next »
