Welcome, Guest. Please login or register.
Did you miss your activation email?
May 21, 2013, 02:08:31 PM
Login with username, password and session length
Search:     Advanced search
* Home Help Search Calendar Links Login Register
+  Machsupport Forum
|-+  Mach Discussion
| |-+  Mach3 under Vista
| | |-+  Vista Pulse Spikes Gone!!!
Pages: 1   Go Down
Print
Author Topic: Vista Pulse Spikes Gone!!!  (Read 1301 times)
ncombes
Active Member
Offline Offline
View Profile
« on: January 02, 2010, 02:33:21 PM »
I am a Newb to this hobby and this forum so please bare with me if you are shaking your head when reading this.  I couldn't get rid of those spikes when I ran the driver test in Vista even after a clean install.  I don't know how or why I tried this next step but it worked and solved my problem.  All I did was switch my power option (control panel--> Power Options) from High Performance to balanced. That was all. I've included the pictures of both tests for reference.
Logged
Greolt
Global Moderator
Offline Offline
View Profile
« Reply #1 on: January 04, 2010, 06:19:25 AM »
I have seen those piano keys before.  Smiley
In BIOS look for a setting called "Enhanced Halt State"  or "C1E Enable" and turn it off.
Greg
Logged
Jeff_Birt
Active Member
Offline Offline
View Profile WWW
« Reply #2 on: January 04, 2010, 07:09:56 AM »
You should really install the OS with all the APCI stuff turned off. That will eliminate most of these types of problems.
Logged
Happy machining , Jeff Birt
Pages: 1   Go Up
Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
