Hi Phil,
This is what i was talking about. But there maybe a problem and if it's true then maybe
it shouldn't be added. In the mill screen the value you input is the Z distance from the axis for feedrate compensation for a diameter. In the lathe screen you are using the Z differently than the mill so you don't want to use it's value. And if you can substitute or change change script to say the X not sure if it will work.
So need some clarification around this. Maybe someone can reply and enlighten us.
Here is a different question:
Would it be worth adding buttons to swap an axis ?
The buttons would swap and reinstate the original axis via a macro.
The screen has been modified for limited rotary, indexing via a stepper,and frankly if you wanted to do more complicated stuff the Mach MILL screen can be utilized or a page added. Just trying to think some out of the box!
