Hello Guest it is April 23, 2024, 03:19:08 AM
Author Topic: How often SS update motion velocity?  (Read 2899 times)
« on: December 14, 2009, 08:16:51 AM »
I think to purchase SmoothStepper. And I need some information. Does SS update motion with rate more than Mach3 can do (10Hz)? When not, how it do motion more smooth?
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
Re: How often SS update motion velocity?
« Reply #1 on: December 14, 2009, 09:43:53 AM »
The SmoothStepper can generate a pulse stream up to 2 MhZ (the SmoothStepper output). Mach sends the SmoothStepper a series of commanded positions, the SmoothStepper buffers them and then generates the needed pulse train to move your machine. You can adjust the SmoothSteppers velocity update rate to match the requirements of your needs as well.
Happy machining , Jeff Birt
