Welcome, Guest. Please login or register.
Did you miss your activation email?
June 19, 2013, 08:32:14 PM
Login with username, password and session length
Search:     Advanced search
* Home Help Search Calendar Links Login Register
+  Machsupport Forum
|-+  Mach Discussion
| |-+  General Mach Discussion
| | |-+  Calling all post processors. ( Help me to help you )
Pages: « 1 2 3 4 5   Go Down
Print
Author Topic: Calling all post processors. ( Help me to help you )  (Read 70672 times)
creep_pea
Active Member
Offline Offline
View Profile
« Reply #40 on: January 02, 2010, 11:11:30 AM »
What version of MasterCam are you using?
On mine it is stored in macx/mill/post
Logged
phbrown
Active Member
Offline Offline
View Profile
« Reply #41 on: January 02, 2010, 02:38:07 PM »
I have CountourCAM,Lazycam, and mache3. Do need to buy a post processor?
Logged
cowpoke
Active Member
Offline Offline
View Profile
« Reply #42 on: January 02, 2010, 08:42:05 PM »
Version X3
Finally found where they are stored after some time reading the reference manual. Not the easiest procedure to change the postprocessors.
Logged
phbrown
Active Member
Offline Offline
View Profile
« Reply #43 on: January 03, 2010, 09:00:02 PM »
I think I do have a postprocessor I just don't know how to make it work. Sometimes I can get a G code into Mach3 with LazyCAM but it won't run. I can' t get anything from Countour cam. The default processor is FANUC.
I guess I will reread the maunal and keep playing around with it.
Logged
phbrown
Active Member
Offline Offline
View Profile
« Reply #44 on: January 03, 2010, 10:24:34 PM »
Logged
LowryIndustries
Active Member
Offline Offline
View Profile
« Reply #45 on: May 24, 2010, 01:49:34 AM »
Creep Pea,
I hope you can help me and I very much thank you in advance for your assistance.
I saw in a post a few years back that you successfully uses Darek Ashburn's BOB board to communicate a PC with a Bridgeport Series II CNC.
I also have one of Darek's BOB boards and a
Nowhere in the documentation does it specifically stated whether the BOB should be wired to the connectors on the ZDI card or directly to the wiring harness bypassing the ZDI card.
I assumed that the BOB card was to be wired directly to the ZDI card bypassing the factory console.
Maybe this is entirely wrong.  Possibly the BOB should be wired directly to the cable harness and not to the ZDI card at all, thereby bypassing the ZDI card.
Please see the attached Pic to see what I did and possibly what I should have done??
http://www.lowryindustries.com/Did I wire this right.htm
Charles.
Logged
numbnutts
Active Member
Offline Offline
View Profile
« Reply #46 on: June 12, 2010, 04:07:16 PM »
Hi guys Im using Mastercam x4 and am trying to get it working with mach 3 (post correct code ) I downloaded the plugin and put it in the mcamx\mill\posts directory. but now Im kinda stumped on the machine type setup part in Mastercam x4, any information on which controller to pick and anything else I may have missed to post g code would be great many thanks.
Logged
Pages: « 1 2 3 4 5   Go Up
Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
