Hello Guest it is April 19, 2024, 06:46:51 PM
Author Topic: EASY 3 axis Mill  (Read 12822 times)
Offline TDAY
  •  165 165
    • Home CNC Stuff
EASY 3 axis Mill
« on: October 22, 2009, 01:20:13 PM »
Hello all,
 Thought i would post my Mill set.Was going for a simple EASY on the eyes layout.Its kinda "plain jane" but works well here on our 3 axis Supermax Vertical Mill.
HTH
Troy
« Last Edit: October 22, 2009, 01:36:36 PM by TDAY »
"I try to put forth the effort,before asking a dum question"
http://homecncstuff.elementfx.com
Offline TDAY
  •  165 165
    • Home CNC Stuff
Re: EASY 3 axis Mill
« Reply #1 on: October 22, 2009, 01:45:03 PM »
Here is more screen shots.
Troy
« Last Edit: October 22, 2009, 01:52:10 PM by TDAY »
« Reply #2 on: October 22, 2009, 09:49:21 PM »
Looks Good Troy. Simple too. I like it.
Offline TDAY
  •  165 165
    • Home CNC Stuff
« Reply #3 on: October 23, 2009, 07:34:54 AM »
Thanks Brett, i hope its of use to someone. :)
Troy
« Reply #4 on: February 10, 2010, 10:33:07 PM »
where should i place the bitmaps.imean location in mach-bitmap folder
Offline TDAY
  •  165 165
    • Home CNC Stuff
« Reply #5 on: February 11, 2010, 07:18:11 AM »
Unzip the New Mill Screen Set folder and place the unzipped folder(which should be labeled New Mill Screen Set) inside of the Mach3 Bitmap folder.Let
me know if it works for you. :)
HTH
Troy
« Last Edit: February 11, 2010, 07:24:14 AM by TDAY »
« Reply #6 on: February 11, 2010, 09:11:33 AM »
yes i did that.and loaded ur screen.
it looks complete different than what  u posted.
May be the bitmaps are not linking properly
http://img63.imageshack.us/img63/7708/newbitmapimage.gif
**one more thing
Thanks for the screen..
Offline TDAY
  •  165 165
    • Home CNC Stuff
« Reply #7 on: February 11, 2010, 09:25:12 AM »
 ??? Thats a old set i did. Maybe i loaded the wrong .set file.
Let me look....
Offline TDAY
  •  165 165
    • Home CNC Stuff
« Reply #8 on: February 11, 2010, 09:33:41 AM »
Yup, wrong .set file, here is correct one.
« Reply #9 on: February 11, 2010, 01:04:41 PM »
yeh its better now.
and it will be much perfect if you could add one more screen with only jog button.
Probably big buttons.so that one can run the complete screen on touch screen.
all jog options we see when we use TAB in regular Mach3 screen.
like if you could create a separate page that will be amazing.
