Welcome, Guest. Please login or register.
Did you miss your activation email?
May 23, 2018, 12:21:35 AM
Login with username, password and session length
Search:     Advanced search
* Home Help Search Calendar Links Login Register
+  Machsupport Forum
|-+  Mach Discussion
| |-+  General Mach Discussion
| | |-+  Config files for Mach3 -->Back-Up Files
Pages: 1   Go Down
Print
Author Topic: Config files for Mach3 -->Back-Up Files  (Read 14652 times)
PeteW
Active Member
Offline Offline
View Profile
« on: September 05, 2006, 07:38:42 AM »
Hello,
Finally purchased Mach3.  Since I am very new to the configuration of Mach3 and the files that affect the way Mach3 runs and is configured I would like to back-up ALL the files that Mach3 uses for my set-up.  Since I final have everything working correctly for my Boss5, I donít want to go through the configuration / set-up again.
A list of all these files would really be great.
Pete W.
Logged
Boss5 SeriesI Running Darek's Universal Breakout Board (http://home.icx.net/~ashburn/) with PentiumII 450, XP Pro SP2, and Mach3 (Demo, to check it out).  Trying to get this working.
ynneb
Guest
« Reply #1 on: September 05, 2006, 07:42:56 AM »
The .xml file found in the mach folder holds your configuration.
Id suggest backing up the whole mach folder though.
Logged
PeteW
Active Member
Offline Offline
View Profile
« Reply #2 on: September 05, 2006, 07:47:56 AM »
Would this be the only file needed to back-up if I were to change parameters such that
Mach3 will work with a different driver control?
So, I would be able to just make a batch file to rename this file accordingly when using a different driver controls?
Logged
HillBilly
Active Member
Offline Offline
View Profile
« Reply #3 on: September 06, 2006, 01:48:03 PM »
If you have special M codes and macropump files (which I now you do) you also need your profile folder.
It will be in the Mach 3 directory and have the same name as your *.xml file.
Darek
Logged
PeteW
Active Member
Offline Offline
View Profile
« Reply #4 on: September 08, 2006, 09:18:49 PM »
Darek
Thanks Darek ... the Uboard is working very well .... and I will not forget to back-up the costume files I got from you.
Pete W.
Logged
Pages: 1   Go Up
Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.20 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
