Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portuguese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 19, 2013, 10:58:44 PM
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Machsupport Forum
Mach Discussion
Mach SDK plugin questions and answers.
XBox360 Controller Plugin New User Info
Pages:
1
2
3
4
5
6
7
8
Go Down
« previous
next »
Author
Topic: XBox360 Controller Plugin New User Info (Read 10109 times)
Leed3
Active Member
Offline
Re: XBox360 Controller Plugin New User Info
Reply #70 on:
April 19, 2012, 10:31:29 AM »
Hi John,
The plugin uses the same code for all operations on the right joystick. So, when you shift it from left-right to up-down, there should be no difference in the speed. I believe that your problem is external to the plugin. It could be 1. the settings in Mach 2. the mill itself 3. the controller or 3. the software powering the controller. Are you using a Microsoft XBox360 controller?
Here is what I would do:
Assign the Z axis to left-right on the left controller and try it. If the problem continues then the cause is either the Mach settings or the Mill. If the problem goes away then the cause is the controller itself or the software powering it.
Mach settings such as motor tuning can cause the steppers to run slow. If all 3 steppers are the same then the motor control settings should all be the same. You can check the controller by recalibrating it in the windows Control Panel (if it is Microsoft). Other controllers have their own calibration program that you can use.
Give those a try and post back the results.
Lee
Logged
JohnHaine
Active Member
Offline
Reply #71 on:
April 19, 2012, 03:53:34 PM »
Thanks Lee for the quick response. When I first tried the controller with Z on the RH LR stick the speed was fine, when I assigned Z to UD on the same stick it was slow, OK again when reassigned to LR. So after your post I tried the calibration routine and it looked fine, no difference between LR and UD directions on RH stick. But I must have changed something because now the UD direction does nothing at all! So looks like I'll have to continue with Z assigned to LR on the RH stick.
I've also fired up Mach3Turn with the controller, again it's great.
A nice feature if you do another release would be to assign a button to "tab" so the jog screen flies out.
Cheers,
John.
Last Edit: April 19, 2012, 03:56:46 PM by JohnHaine
Logged
Leed3
Active Member
Offline
Reply #72 on:
April 19, 2012, 06:37:04 PM »
Hi John,
All I can say for sure is that it is not a plugin problem. If the controller works fine on Mach Lathe, then the controller and software are fine. It could be Mach itself. You may have to reinstall Mach itself. But, before doing that, I would suggest installing Mach (lockdown version not Beta) on another pc and trying it.
I like the idea of adding the tab and will do so.
Good luck
Lee
Logged
JohnHaine
Active Member
Offline
Reply #73 on:
April 20, 2012, 09:24:51 AM »
Yes, it's weird - the RH joystick works fine with Turn but totally unresponsive on Mill. I have been meaning to reinstall the latest version of Mach anyway so will give it a try. Glad my feature suggestion was useful!
John.
Logged
JohnHaine
Active Member
Offline
Reply #74 on:
April 27, 2012, 05:00:43 AM »
Hi Lee, just to say that I have just installed the latest lockdown Mach version and the XBOX plugin and it now works perfectly.
John.
Logged
wbleeker
Active Member
Offline
Reply #75 on:
July 23, 2012, 12:42:45 AM »
Hi Lee
I am trying to install the plugin and cant get it to install itself when i click on it, when I click the screen flashes and then goes back to normal?
Will
Logged
Pages:
1
2
3
4
5
6
7
8
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Mach SDK plugin questions and answers.
===> Finished Plugins for Download
=> VB and the development of wizards
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Screen designer tips and tutorials
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> Machscreen Screen Designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
=> Show"N"Tell ( What you have made with your CNC machine.)
=> Building or Buying a Wood routing table.. Beginnners guide..
=> Show"N"Tell ( Your Machines)
G-Code, CAD, and CAM
=> G-Code, CAD, and CAM discussions
=> LazyCam (Beta)
Third party software and hardware support forums.
=> LazyTurn
=> GearoticMotion Preliminary testing
=> Tempest Trajectory Planner
=> Contec
=> CS-Lab
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Third party software and hardware support forums.
=> Galil
=> Newfangled Solutions Mach3 Wizards
=> Newfangled Mill Wizard
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
=> Promote and discuss your product
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
=> Forum suggestions and report forum problems.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
